J. M. Rotter, Bulk Solids Handling: Equipment Selection and Operation, p.99, 2008.
A. Dogangun, Z. Karaca, A. Durmus, and H. Sezen, Cause of Damage and Failures in Silo Structures, Journal of Performance of Constructed Facilities, vol.23, issue.2, p.65, 2009.
DOI : 10.1061/(ASCE)0887-3828(2009)23:2(65)
A. B. Dutta, Global Research Analysis, vol.2, p.41, 2013.
C. H. Liu, S. R. Nagel, D. A. Schecter, S. N. Coppersmith, T. S. Majumdar et al., , p.513, 1995.
T. S. Majmudar and R. P. Behringer, Nature, pp.435-1079, 2005.
L. Vanel, D. Howell, D. Clark, R. P. Behringer, and E. Clément, Phys. Rev. E, p.60, 1999.
H. A. Janssen, , p.1045, 1895.
R. M. Nedderman, Statics and kinematics of granular materials, 1992.
DOI : 10.1017/CBO9780511600043
L. Vanel and E. Clément, Pressure screening and fluctuations at the bottom of a granular column, The European Physical Journal B, vol.11, issue.3, p.525, 1999.
DOI : 10.1007/s100510050965
G. Ovarlez, C. Fond, and E. Clément, Overshoot effect in the Janssen granular column: A crucial test for granular mechanics, Physical Review E, vol.326, issue.6, p.60302, 2003.
DOI : 10.1103/PhysRevE.53.4673
URL : https://hal.archives-ouvertes.fr/hal-00195229
Y. Bertho, F. Giorgiutti-dauphiné, and J. P. Hulin, Dynamical Janssen Effect on Granular Packing with Moving Walls, Physical Review Letters, vol.60, issue.14, p.144301, 2003.
DOI : 10.1103/PhysRevE.60.R5040
C. Perge, M. A. Aguirre, P. A. Gago, L. A. Pugnaloni, D. L. Tourneau et al., Evolution of pressure profiles during the discharge of a silo, Physical Review E, vol.38, issue.2, p.21303, 2012.
DOI : 10.1016/j.powtec.2007.11.001
URL : https://hal.archives-ouvertes.fr/hal-00662418
T. Cambau, J. Hure, and J. Marthelot, Local stresses in the Janssen granular column, Physical Review E, vol.2, issue.2, p.22204, 2013.
DOI : 10.1007/s11104-012-1316-2
URL : https://hal.archives-ouvertes.fr/hal-01056991
Y. Wang, Y. Lu, and J. Y. Ooi, A numerical study of wall pressure and granular flow in a flat-bottomed silo, Powder Technology, vol.282, p.43, 2015.
DOI : 10.1016/j.powtec.2015.01.078
R. Back, . Granul, and . Matter, , p.723, 2011.
Y. Wang, Y. Lu, J. Y. Ooi, . Eng, and . Struct, , p.1308, 2013.
Z. Zhong, J. Y. Ooi, and J. M. Rotter, The sensitivity of silo flow and wall stresses to filling method, Engineering Structures, vol.23, issue.7, p.756, 2001.
DOI : 10.1016/S0141-0296(00)00099-7
M. Ostendorf, J. Schwedes, J. Bohrnsen, and H. Antes, Task Quarterly, vol.7, p.611, 2003.
W. H. Horton and S. C. Durham, Imperfections, a main contributor to scatter in experimental values of buckling load, International Journal of Solids and Structures, vol.1, issue.1, p.59, 1965.
DOI : 10.1016/0020-7683(65)90015-6
G. J. Simitses, Buckling and Postbuckling of Imperfect Cylindrical Shells: A Review, Applied Mechanics Reviews, vol.39, issue.10, p.1517, 1986.
DOI : 10.1115/1.3149506
A. Jansseune, W. De-corte, and J. Belis, Imperfection sensitivity of locally supported cylindrical silos subjected to uniform axial compression, International Journal of Solids and Structures, vol.96, p.92, 2016.
DOI : 10.1016/j.ijsolstr.2016.06.019
]. E. Skukis, O. Ozolins, K. Kalnins, M. A. Arbelo, and P. Eng, , p.1023, 2017.
E. Virot, T. Kreilos, T. M. Schneider, and S. M. Rubinstein, Stability Landscape of Shell Buckling, Physical Review Letters, vol.119, issue.22, p.224101, 2017.
DOI : 10.1115/1.4034431
G. Gutiérrez, C. Colonnello, P. Boltenhagen, J. R. Darias, R. Peralta-fabi et al., Silo Collapse under Granular Discharge, Physical Review Letters, vol.25, issue.1, p.18001, 2015.
DOI : 10.1073/pnas.1003250107
C. Colonnello, L. I. Reyes, E. Clément, and G. Gutiérrez, Behavior of grains in contact with the wall of a silo during the initial instants of a discharge-driven collapse, Physica A: Statistical Mechanics and its Applications, vol.398, p.35, 2014.
DOI : 10.1016/j.physa.2013.12.010
E. Gallego, A. Ruiz, and P. J. Aguado, Simulation of silo filling and discharge using ANSYS and comparison with experimental data, Computers and Electronics in Agriculture, vol.118, p.281, 2015.
DOI : 10.1016/j.compag.2015.09.014
C. Zhao, H. Matsuda, S. Lou, C. Morita, and A. Koga, Visualization of Buckling on Thin-walled Cylindrical Shell by Digital Image Correlation Method, Applied Mathematics & Information Sciences, vol.7, issue.3, p.999, 2013.
DOI : 10.12785/amis/070318
H. Edelsbrunner and J. L. Harer, Computational topology: an introduction, 2010.
DOI : 10.1090/mbk/069
G. Carlsson, Topology and data, Bulletin of the American Mathematical Society, vol.46, issue.2, p.255, 2009.
DOI : 10.1090/S0273-0979-09-01249-X
M. Krámar, R. Levanger, J. Tithof, B. Suri, M. Xu et al., Analysis of Kolmogorov flow and Rayleigh???B??nard convection using persistent homology, Physica D: Nonlinear Phenomena, vol.334, p.82, 2016.
DOI : 10.1016/j.physd.2016.02.003
Y. Yoshimaru and . Naca, , 1955.
V. Pini, J. J. Ruz, P. M. Kosaka, O. Malvar, M. Calleja et al., Sci. Rep, vol.6, 2016.
L. Kondic, M. Kramár, L. Koval?inová, and K. Mischaikow, EPJ Web of Conferences, p.15014, 2017.
R. A. Fisher, Ann. Hum. Genet, vol.7, p.179, 1936.
G. Gutiérrez, P. Boltenhagen, J. Lanuza, and E. Clément, Traffic and Granular Flow'07, p.517, 2009.
N. Yamaki, K. Otomo, and K. Matsuda, Experiments on the postbuckling behavior of circular cylindrical shells under compression, Experimental Mechanics, vol.13, issue.7, p.23, 1975.
DOI : 10.1115/1.3564582
G. W. Hunt, G. J. Lord, M. A. Peletier, and D. Cont, Dyn. B, vol.3, p.505, 2003.
K. A. Seffen, S. V. Stott, and J. , Surface Texturing Through Cylinder Buckling, Journal of Applied Mechanics, vol.81, issue.6, p.61001, 2014.
DOI : 10.1115/1.4026331
