Handover and Load Balancing for Distributed Network Control: Applications in ITS Message Dissemination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this paper, we build upon our prior work on D2-ITS, a flexible and extensible framework to dynamically distribute network control to enable message dissemination in Intelligent Transport Systems (ITS), and extend it with handover and load balancing capabilities. More specifically, D2-ITS' new handover feature allows a controller to automatically "delegate" control of a vehicle to another controller as the vehicle moves. Control delegation can also be used as a way to balance load among controllers and ensure that required application quality of service is maintained. We showcase D2-ITS' handover and load-balancing features using the Mininet-Wifi network simula-tor/emulator. Our preliminary experiments show D2-ITS' ability to seamlessly handover control of vehicles as they move.
handover-load-balancing(2).pdf (1.84 Mo) Télécharger le fichier
hal-01849907 , version 1 (26-07-2018)
  • HAL Id : hal-01849907 , version 1
Anuj Kaul, Li Xue, Katia Obraczka, Mateus Augusto Silva Santos, Thierry Turletti. Handover and Load Balancing for Distributed Network Control: Applications in ITS Message Dissemination. ICCCN 2018 - 27th International Conference on Computer Communications and Networks, Jul 2018, Hangzhou, China. ⟨hal-01849907⟩
251 Consultations
1135 Téléchargements
