Recommendations for the Use of Serious Games in Neurodegenerative Disorders: 2016 Delphi Panel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Psychology Année : 2017
Valeria Manera
  • Fonction : Auteur
  • PersonId : 980090
Hovannes Agopyan
  • Fonction : Auteur
Michel Benoit
Jérémy Bourgeois
  • Fonction : Auteur
  • PersonId : 768906
  • IdRef : 169989100
Jonathan Bredin
  • Fonction : Auteur
Renaud David
  • Fonction : Auteur
  • PersonId : 993775
Auriane Gros
  • Fonction : Auteur
  • PersonId : 998179
Guillaume Sacco
  • Fonction : Auteur
  • PersonId : 962214
Sylvie Serret
  • Fonction : Auteur
  • PersonId : 1033436
Philippe Robert
  • Fonction : Auteur
  • PersonId : 962170
The use of Serious Games (SG) in the health domain is expanding. In the field of neurodegenerative disorders (ND) such as Alzheimer’s disease, SG are currently employed both to support and improve the assessment of different functional and cognitive abilities, and to provide alternative solutions for patients’ treatment, stimulation, and rehabilitation. As the field is quite young, recommendations on the use of SG in people with ND are still rare. In 2014 we proposed some initial recommendations (Robert et al., 2014). The aim of the present work was to update them, thanks to opinions gathered by experts in the field during an expert Delphi panel. Results confirmed that SG are adapted to elderly people with mild cognitive impairment (MCI) and dementia, and can be employed for several purposes, including assessment, stimulation, and improving wellbeing, with some differences depending on the population (e.g., physical stimulation may be better suited for people with MCI). SG are more adapted for use with trained caregivers (both at home and in clinical settings), with a frequency ranging from 2 to 4 times a week. Importantly, the target of SG, their frequency of use and the context in which they are played depend on the SG typology (e.g., Exergame, cognitive game), and should be personalized with the help of a clinician.
Valeria_Frontiers2016.pdf (767.33 Ko) Télécharger le fichier
hal-01850326 , version 1 (27-07-2018)
  • HAL Id : hal-01850326 , version 1
Valeria Manera, Grégory Ben-Sadoun, Teun Aalbers, Hovannes Agopyan, Florence Askenazy, et al.. Recommendations for the Use of Serious Games in Neurodegenerative Disorders: 2016 Delphi Panel. Frontiers in Psychology, 2017. ⟨hal-01850326⟩
252 Consultations
193 Téléchargements
