Semiring Provenance over Graph Databases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We generalize three existing graph algorithms to compute the provenance of regular path queries over graph databases, in the framework of provenance semirings – algebraic structures that can capture different forms of provenance. Each algorithm yields a different trade-off between time complexity and generality, as each requires different properties over the semiring. Together, these algorithms cover a large class of semirings used for provenance (top-k, security, etc.). Experimental results suggest these approaches are complementary and practical for various kinds of provenance indications, even on a relatively large transport network.
tapp2018-paper-ramusat.pdf (593.98 Ko) Télécharger le fichier
hal-01850510 , version 1 (27-07-2018)
  • HAL Id : hal-01850510 , version 1
Yann Ramusat, Silviu Maniu, Pierre Senellart. Semiring Provenance over Graph Databases. 10th USENIX Workshop on the Theory and Practice of Provenance (TaPP 2018), Jul 2018, London, United Kingdom. ⟨hal-01850510⟩
284 Consultations
102 Téléchargements
