Connecting Width and Structure in Knowledge Compilation
Several query evaluation tasks can be done via knowledge compilation: the query result is compiled
as a lineage circuit from which the answer can be determined. For such tasks, it is important
to leverage some width parameters of the circuit, such as bounded treewidth or pathwidth, to convert
the circuit to structured classes, e.g., deterministic structured NNFs (d-SDNNFs) or OBDDs.
In this work, we show how to connect the width of circuits to the size of their structured representation,
through upper and lower bounds. For the upper bound, we show how bounded-treewidth
circuits can be converted to a d-SDNNF, in time linear in the circuit size. Our bound, unlike
existing results, is constructive and only singly exponential in the treewidth. We show a related
lower bound on monotone DNF or CNF formulas, assuming a constant bound on the arity (size of
clauses) and degree (number of occurrences of each variable). Specifically, any d-SDNNF (resp.,
SDNNF) for such a DNF (resp., CNF) must be of exponential size in its treewidth; and the
same holds for pathwidth when compiling to OBDDs. Our lower bounds, in contrast with most
previous work, apply to any formula of this class, not just a well-chosen family. Hence, for our
language of DNF and CNF, pathwidth and treewidth respectively characterize the efficiency of
compiling to OBDDs and (d-)SDNNFs, that is, compilation is singly exponential in the width
parameter. We conclude by applying our lower bound results to the task of query evaluation.
