Pervasive Attention: 2D Convolutional Neural Networks for Sequence-to-Sequence Prediction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Current state-of-the-art machine translation systems are based on encoder-decoder architectures, that first encode the input sequence, and then generate an output sequence based on the input encoding. Both are interfaced with an attention mechanism that recombines a fixed encoding of the source tokens based on the decoder state. We propose an alternative approach which instead relies on a single 2D convolutional neural network across both sequences. Each layer of our network re-codes source tokens on the basis of the output sequence produced so far. Attention-like properties are therefore pervasive throughout the network. Our model yields excellent results, outperforming state-of-the-art encoder-decoder systems, while being conceptually simpler and having fewer parameters.
paper.pdf (1.66 Mo) Télécharger le fichier
hal-01851612 , version 1 (10-08-2018)
hal-01851612 , version 2 (03-09-2018)
hal-01851612 , version 3 (04-09-2018)
  • HAL Id : hal-01851612 , version 3
Maha Elbayad, Laurent Besacier, Jakob Verbeek. Pervasive Attention: 2D Convolutional Neural Networks for Sequence-to-Sequence Prediction. CoNLL 2018 - Conference on Computational Natural Language Learning, Oct 2018, Brussels, Belgium. pp.97-107. ⟨hal-01851612v3⟩
1007 Consultations
864 Téléchargements
