Pervasive Attention: 2D Convolutional Neural Networks for Sequence-to-Sequence Prediction
Abstract : Current state-of-the-art machine translation systems are based on encoder-decoder architectures, that first encode the input sequence, and then generate an output sequence based on the input encoding. Both are interfaced with an attention mechanism that recombines a fixed encoding of the source tokens based on the decoder state. We propose an alternative approach which instead relies on a single 2D convolutional neural network across both sequences. Each layer of our network re-codes source tokens on the basis of the output sequence produced so far. Attention-like properties are therefore pervasive throughout the network. Our model yields excellent results, outperforming state-of-the-art encoder-decoder systems, while being conceptually simpler and having fewer parameters.
Complete list of metadatas
Cited literature [46 references]  Display  Hide  Download
https://hal.inria.fr/hal-01851612
Contributor : Thoth Team <>
Submitted on : Monday, September 3, 2018 - 12:16:21 PM
Last modification on : Tuesday, January 7, 2020 - 9:58:01 AM
File
paper.pdf
Identifiers
  • HAL Id : hal-01851612, version 2
Citation
Maha Elbayad, Laurent Besacier, Jakob Verbeek. Pervasive Attention: 2D Convolutional Neural Networks for Sequence-to-Sequence Prediction. Conference on Computational Natural Language Learning, Oct 2018, Brussels, Belgium. ⟨hal-01851612v2⟩
Share
Metrics
Record views
52
Files downloads
206
