A Hypersequent Calculus with Clusters for Tense Logic over Ordinals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Prior's tense logic forms the core of linear temporal logic, with both past-and future-looking modalities. We present a sound and complete proof system for tense logic over ordinals. Technically , this is a hypersequent system, enriched with an ordering, clusters, and annotations. The system is designed with proof search algorithms in mind, and yields an optimal coNP complexity for the validity problem. It entails a small model property for tense logic over ordinals: every satisfiable formula has a model of order type at most ω². It also allows to answer the validity problem for ordinals below or exactly equal to a given one.
main.pdf (538.6 Ko) Télécharger le fichier
hal-01852077 , version 1 (31-07-2018)
hal-01852077 , version 2 (13-12-2018)
Paternité - Partage selon les Conditions Initiales
David Baelde, Anthony Lick, Sylvain Schmitz. A Hypersequent Calculus with Clusters for Tense Logic over Ordinals. 38th IARCS Annual Conference on Foundations of Software Technology and Theoretical Computer Science, 2018, Ahmedabad, India. pp.15:1--15:19, ⟨10.4230/LIPIcs.FSTTCS.2018.15⟩. ⟨hal-01852077v1⟩
271 Consultations
79 Téléchargements
