Analysis and calibration of a linear model for structured cell populations with unidirectional motion : Application to the morphogenesis of ovarian follicles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Applied Mathematics Année : 2019
We analyze a multi-type age dependent model for cell populations subject to unidirectional motion, in both a stochastic and deterministic framework. Cells are distributed into successive layers; they may divide and move irreversibly from one layer to the next. We adapt results on the large-time convergence of PDE systems and branching processes to our context, where the Perron-Frobenius or Krein-Rutman theorem cannot be applied. We derive explicit analytical formulas for the asymptotic cell number moments, and the stable age distribution. We illustrate these results numerically and we apply them to the study of the morphodynamics of ovarian follicles. We prove the structural parameter identifiability of our model in the case of age independent division rates. Using a set of experimental biological data, we estimate the model parameters to fit the changes in the cell numbers in each layer during the early stages of follicle development.
M116133_published_version.pdf (2.29 Mo) Télécharger le fichier
hal-01852560 , version 1 (01-08-2018)
hal-01852560 , version 2 (07-03-2019)
Copyright (Tous droits réservés)
Frédérique Clément, Frédérique Robin, Romain Yvinec. Analysis and calibration of a linear model for structured cell populations with unidirectional motion : Application to the morphogenesis of ovarian follicles. SIAM Journal on Applied Mathematics, 2019, 79 (1), pp.207-229. ⟨10.1137/17M1161336⟩. ⟨hal-01852560v2⟩
310 Consultations
122 Téléchargements
