Semantic BMS: Ontology for Analysis of Building Operation Efficiency - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
Adam Kučera
  • Function : Author
  • PersonId : 998661
Tomáš Pitner
  • Function : Author
  • PersonId : 983302
Building construction has gone through a significant change with the emerging spread of ICT during last decades. Intelligent buildings are equipped with building automation systems (BAS) that can be remotely controlled and programmed. However, such systems lack convenient tools for data inspection, making building performance and efficiency analysis demanding on large sites. The paper presents an adaptation of Semantic Sensor Network ontology for use in the field of building operation analysis. The proposed Semantic BMS ontology enriches the SSN with a model of building automation data points and describes relations between BAS and physical properties of a building. Proposed ontology allows facility managers to conveniently query BAS systems, providing decision support for tactical and strategic level planning.
467210_1_En_29_Chapter.pdf (337.98 Ko) Télécharger le fichier
Dates and versions
hal-01852610 , version 1 (02-08-2018)
Attribution - CC BY 4.0
Identifiers
Cite
Adam Kučera, Tomáš Pitner. Semantic BMS: Ontology for Analysis of Building Operation Efficiency. 12th International Symposium on Environmental Software Systems (ISESS), May 2017, Zadar, Croatia. pp.349-359, ⟨10.1007/978-3-319-89935-0_29⟩. ⟨hal-01852610⟩
66 View
140 Download
Share
