Framework for Enabling Technical and Organizational Interoperability in the Management of Environmental Crises and Disasters - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1) , (2) , (1) , (1) , (1) , (1)
1
2
Interoperability is a core component in management of crises and disasters. Crises require interoperability on several different levels: physical (communication, devices and tools), operational (crisis response procedures and protocols) and document level (information exchange). Here we present the Framework that facilitates interoperability on a level that relieves a crisis manager from most burdens related to crisis response (e.g., being available to access sensor data or communicate with other responders). The software components in the Framework are described, as well as the profiling approach that is necessitated for functioning interoperability at such a demanding level. The Framework can be implemented for dealing with environmental challenges through real-time monitoring and response. The frequency of disasters is expected to increase in the forthcoming future mostly due to environmental changes, thus emphasizing the need for interoperability approaches as the one presented in this paper.
467210_1_En_24_Chapter.pdf (370.29 Ko) Télécharger le fichier
Dates and versions
hal-01852614 , version 1 (02-08-2018)
Attribution - CC BY 4.0
Identifiers
Cite
Refiz Duro, Mert Gençtürk, Gerald Schimak, Peter Kutschera, Denis Havlik, et al.. Framework for Enabling Technical and Organizational Interoperability in the Management of Environmental Crises and Disasters. 12th International Symposium on Environmental Software Systems (ISESS), May 2017, Zadar, Croatia. pp.290-301, ⟨10.1007/978-3-319-89935-0_24⟩. ⟨hal-01852614⟩
59 View
58 Download
Share
