Approaches to Fuse Fixed and Mobile Air Quality Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gerhard Dünnebeil
  • Fonction : Auteur
  • PersonId : 1035248
Martina Marjanović
  • Fonction : Auteur
  • PersonId : 1035249
Ivana Podnar Žarko
  • Fonction : Auteur
  • PersonId : 1035250
Nowadays, air quality monitoring is identified as one of the key impacts in assessing the quality of life in urban areas. Traditional measuring procedures include expensive equipment in the fixed monitoring stations which is not suitable for urban areas because of the low spatio-temporal density of measurements. On the other hand, the technological development of small wearable sensor devices has created new opportunities for air pollution monitoring. Therefore, in this paper we discuss statistical approaches to fuse the data from fixed and mobile sensors for air quality monitoring.
467210_1_En_7_Chapter.pdf (1.02 Mo) Télécharger le fichier
hal-01852641 , version 1 (02-08-2018)
Paternité
Gerhard Dünnebeil, Martina Marjanović, Ivana Podnar Žarko. Approaches to Fuse Fixed and Mobile Air Quality Sensors. 12th International Symposium on Environmental Software Systems (ISESS), May 2017, Zadar, Croatia. pp.71-84, ⟨10.1007/978-3-319-89935-0_7⟩. ⟨hal-01852641⟩
45 Consultations
80 Téléchargements
