Drags: A Simple Algebraic Framework For Graph Rewriting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We are interested here in a natural generalization of term rewriting techniques to what we call drags, viz. finite, directed, ordered multigraphs. Each vertex is labeled by a function symbol, the arity of which governs the number of vertices to which it relates by an incoming edge in the graph. To this end, we develop a rich algebra of drags which generalizes the familiar term algebra and its associated rewriting capabilities. Viewing graphs as terms provides an initial building block for rewriting with such graphs, that should impact the many areas where computations take place on graphs.
GraphRewritingTG-Final.pdf (212.51 Ko) Télécharger le fichier
hal-01853836 , version 1 (05-08-2018)
  • HAL Id : hal-01853836 , version 1
Nachum Dershowitz, Jean-Pierre Jouannaud. Drags: A Simple Algebraic Framework For Graph Rewriting. TERMGRAPH 2018 - 10th International Workshop on Computing with Terms and Graphs, Jul 2018, Oxford, United Kingdom. ⟨hal-01853836⟩
129 Consultations
192 Téléchargements
