New interface
Conference papers
A modular framework for model-based visual tracking using edge, texture and depth features
Souriya Trinh 1 Fabien Spindler 1 Eric Marchand 1 François Chaumette 1
1 RAINBOW - Sensor-based and interactive robotics
Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : We present in this paper a modular real-time model-based visual tracker. It is able to fuse different types of measurement, that is, edge points, textured points, and depth map, provided by one or multiple vision sensors. A confidence index is also proposed for determining if the outputs of the tracker are reliable or not. As expected, experimental results show that the more various measurements are combined, the more accurate and robust is the tracker. The corresponding C++ source code is available for the community in the ViSP library.
Document type :
Conference papers
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/hal-01853972
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Monday, August 6, 2018 - 9:49:59 AM
Last modification on : Saturday, August 6, 2022 - 3:32:59 AM
Long-term archiving on: : Wednesday, November 7, 2018 - 2:54:54 PM
File
2018_iros_trinh.pdf
Identifiers
Citation
Souriya Trinh, Fabien Spindler, Eric Marchand, François Chaumette. A modular framework for model-based visual tracking using edge, texture and depth features. IROS'18 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Oct 2018, Madrid, Spain. pp.89-96, ⟨10.1109/IROS.2018.8594003⟩. ⟨hal-01853972⟩
Share
Metrics
Record views
499
Files downloads
933
