Multi-Agent Based Implementation of an Embedded Image Processing System in FPGA for Precision Agriculture Using UAVs, p.15 ,
Combining Service-Oriented Computing with Embedded Systems -A Robotics Case Study, p.27 ,
Kleinjohann Integration of Robot Operating System and Ptolemy for Design of Real-Time Multi-robots Environments, p.38 ,
, Tiago P. Nascimento, and Thiago Henrique Menezes Bezerra System-Level Design
, , p.51
, , p.64
Thomas Göthel, and Sabine Glesner Structural Contracts ? Motivating Contracts to Ensure Extra-Functional Semantics, p.77 ,
Kim Grüttner, and Wolfgang Nebel Combining an Iterative State-Based Timing Analysis with a Refinement Checking Technique, p.88 ,
, Tayfun Gezgin, Björn Koopmann, and Achim Rettberg
Core System Design Hierarchical Multicore-Scheduling for Virtualization of Dependent Real-Time Systems ,
and Achim Rettberg Analysis of Process Traces for Mapping Dynamic KPN Applications to MPSoCs, p.116 ,
, , p.128
Kasra Moazzemi, and Gunar Schirner Memory System Design Taming the Memory Demand Complexity of Adaptive Vision Algorithms, p.145 ,
, , p.159
Alves, and Luigi Carro Managing Cache Memory Resources in Adaptive Many-Core Systems, p.172 ,
Profile to Couple the Production Code Generator TargetLink with UML Design Tools, p.185 ,
High-Level Performance Estimation for DSE Using Calibrated Weight Tables, Kasra Moazzemi ,
, , p.210
