L1-Norm Regularized Deconvolution of Functional MRI BOLD Signal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2018
Deconvolution methods are used to denoise the blood oxygen level-dependent (BOLD) response, the signal that forms the basis of functional MRI (fMRI). In this work we propose a novel approach based on a temporal regularized deconvolution of the BOLD fMRI signal with the least absolute shrinkage and selection operator (LASSO) model, solved using the angle regression algorithm (LARS). In this way we were able to recover the underlying neurons activations and their dynamics
CaUCA_Costantini_poster.pdf (1.43 Mo) Télécharger le fichier
hal-01855505 , version 1 (08-08-2018)
  • HAL Id : hal-01855505 , version 1
Isa Costantini, Patryk Filipiak, Kostiantyn Maksymenko, Samuel Deslauriers-Gauthier, Rachid Deriche. L1-Norm Regularized Deconvolution of Functional MRI BOLD Signal. C@UCA, Jun 2018, Fréjus, France. ⟨hal-01855505⟩
82 Consultations
55 Téléchargements
