Fast Global Illumination with Discrete Stochastic Microfacets Using a Filterable Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2018
Beibei Wang
Lu Wang
  • Fonction : Auteur
  • PersonId : 873867
Many real-life materials have a sparkling appearance, whether by design or by nature. Examples include metallic paints, sparkling varnish but also snow. These sparkles correspond to small, isolated, shiny particles reflecting light in a specific direction, on the surface or embedded inside the material. The particles responsible for these sparkles are usually small and discontinuous. These characteristics make it difficult to integrate them efficiently in a standard rendering pipeline, especially for indirect illumination. Existing approaches use a 4-dimensional hierarchy, searching for light-reflecting particles simultaneously in space and direction. The approach is accurate, but still expensive. In this paper, we show that this 4-dimensional search can be approximated using separate 2-dimensional steps. This approximation allows fast integration of glint contributions for large footprints, reducing the extra cost associated with glints be an order of magnitude.
glint_camera.pdf (60.5 Mo) Télécharger le fichier
hal-01856980 , version 1 (13-08-2018)
Beibei Wang, Lu Wang, Nicolas Holzschuch. Fast Global Illumination with Discrete Stochastic Microfacets Using a Filterable Model. Computer Graphics Forum, 2018, 37 (7), pp.55-64. ⟨10.1111/cgf.13547⟩. ⟨hal-01856980⟩
589 Consultations
269 Téléchargements
