Kernel-predicting convolutional networks for denoising Monte Carlo renderings, ACM Trans Graph, vol.36, issue.4, p.5, 2017. ,
The fast bilateral solver, Proc. Eur. Conf. Comput. Vis. 1, vol.8, p.16, 2016. ,
A non-local algorithm for image denoising, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, vol.6, p.18, 2005. ,
A naturalistic open source movie for optical flow evaluation, Proc. Eur. Conf. Comput. Vis. 2, 9, vol.10, p.18, 2012. ,
Deeplab: Semantic image segmentation with deep convolutional nets, atrous convolution, and fully connected crfs, IEEE Trans Pattern Anal Mach Intell, vol.40, issue.4, p.15, 2018. ,
Universal correspondence network, Adv. Neural Inf. Process. Syst, issue.3, 2016. ,
Deformable convolutional networks, Proc. Int. Conf. Comput. Vis, vol.4, p.6, 2017. ,
An application of Markov random fields to range sensing, Adv. Neural Inf. Process. Syst, vol.8, p.16, 2006. ,
The pascal visual object classes challenge: A retrospective, Int J Comput Vis, vol.111, issue.1, p.15, 2015. ,
Edge-preserving decompositions for multi-scale tone and detail manipulation, vol.27, p.3, 2008. ,
Image guided depth upsampling using anisotropic total generalized variation, Proc. Int. Conf. Comput. Vis. 1, vol.12, p.16, 2013. ,
Variational depth superresolution using example-based edge representations, Proc. Int. Conf. Comput. Vis. 3, 2015. ,
Blade: Filter learning for general purpose computational photography, Proc. IEEE Conf. Computational Photography, p.3, 2018. ,
Learning dynamic guidance for depth image enhancement, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, vol.2, p.9, 2017. ,
Proposal flow, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01240281
Robust guided image filtering using nonconvex potentials, International Journal of Computer Vision, vol.40, issue.1, pp.192-207, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01279857
Semantic contours from inverse detectors, Proc. Int. Conf. Comput. Vis, p.14, 2011. ,
Guided image filtering, IEEE Trans Pattern Anal Mach Intell, vol.35, issue.6, p.16, 2013. ,
Deep residual learning for image recognition, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, vol.5, p.14, 2016. ,
Evaluation of cost functions for stereo matching, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, vol.9, p.10, 2007. ,
Fast cost-volume filtering for visual correspondence and beyond, IEEE Trans Pattern Anal Mach Intell, vol.35, issue.2, pp.504-511, 2013. ,
Depth map super-resolution by deep multi-scale guidance, Proc. Eur. Conf. Comput. Vis. 2, 3, 8, 9, vol.10, p.18, 2016. ,
Batch normalization: Accelerating deep network training by reducing internal covariate shift, Proc. Int. Conf. Machine Learning 5, 2015. ,
Spatial transformer networks, Adv. Neural Inf. Process. Syst, vol.3, p.6, 2015. ,
Dynamic filter networks, Adv. Neural Inf. Process. Syst, vol.3, p.4, 2016. ,
Structure-preserving image smoothing via region covariances, ACM Trans Graph, vol.32, issue.6, p.14, 2013. ,
Accurate image super-resolution using very deep convolutional networks, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, vol.5, p.17, 2016. ,
Adam: A method for stochastic optimization, Proc. Int. Conf. Learning Representations, p.10, 2015. ,
Joint bilateral upsampling, ACM Trans Graph, vol.26, issue.3, p.16, 2007. ,
Efficient inference in fully connected crfs with gaussian edge potentials, Adv. Neural Inf. Process. Syst, vol.14, p.15, 2011. ,
ImageNet classification with deep convolutional neural networks, In: Adv. Neural Inf. Process. Syst, vol.2, p.10, 2012. ,
A closed-form solution to natural image matting, IEEE Trans Pattern Anal Mach Intell, vol.30, issue.2, pp.228-242, 2008. ,
Deep joint image filtering, Proc. Eur. Conf. Comput. Vis, vol.16, p.18, 2016. ,
Joint image filtering with deep convolutional networks, IEEE Trans Pattern Anal Mach Intell, vol.41, issue.8, p.17, 1909. ,
Fully convolutional networks for semantic segmentation, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, vol.6, p.18, 2015. ,
Depth enhancement via low-rank matrix completion, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, vol.9, p.10, 2014. ,
How to evaluate foreground maps?, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, p.12, 2014. ,
Burst denoising with kernel prediction networks, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, vol.3, p.4, 2018. ,
Video frame interpolation via adaptive convolution, Proc. IEEE Conf. Comput. Vis. Pattern Recognit. 3, 4, 5, vol.6, p.18, 2017. ,
Deconvolution and checkerboard artifacts, Distill, vol.1, issue.10, p.17, 2016. ,
High quality depth map upsampling for 3D-ToF cameras, Proc. Int. Conf. Comput. Vis. 1, 3, 8, vol.11, p.16, 2011. ,
Automatic differentiation in PyTorch, 2017. ,
EpicFlow: Edge-preserving interpolation of correspondences for optical flow, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, pp.1164-1172, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01142656
A deep primal-dual network for guided depth super-resolution, Proc. British Machine Vision Conference, vol.3, p.12, 2016. ,
ATGV-Net: Accurate depth super-resolution, Proc. Eur. Conf. Comput. Vis. 3, 2016. ,
RAISR: Rapid and accurate image super resolution, IEEE Trans Computational Imaging, vol.3, issue.1, pp.110-125, 2017. ,
U-net: Convolutional networks for biomedical image segmentation, Proc. Intl. Conf. on Medical image computing and computer-assisted intervention 17, 2015. ,
Learning conditional random fields for stereo, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, p.10, 2007. ,
Mutual-structure for joint filtering, Proc. Int. Conf. Comput. Vis. 1, 2015. ,
Real-time single image and video super-resolution using an efficient sub-pixel convolutional neural network, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, 2016. ,
Indoor segmentation and support inference from rgbd images, Proc. Eur. Conf. Comput. Vis. 8, 9, vol.10, p.18, 2012. ,
Two-stream convolutional networks for action recognition in videos, Adv. Neural Inf. Process. Syst, issue.4, 2014. ,
Very deep convolutional networks for large-scale image recognition, Proc. Int. Conf. Learning Representations, p.17, 2015. ,
Pixel-adaptive convolutional neural networks, Proc. IEEE Conf. Comput. Vis. Pattern Recognit. 8, 9, vol.10, p.17, 2019. ,
Locally adapted hierarchical basis preconditioning, vol.25, pp.1135-1143, 2006. ,
Learning guided convolutional network for depth completion, 2019. ,
Bilateral filtering for gray and color images, Proc. Int. Conf. Comput. Vis. 1, vol.2, p.3, 1998. ,
Denoising with kernel prediction and asymmetric loss functions, ACM Trans Graph, vol.37, issue.4, p.5, 2018. ,
Optimized color sampling for robust matting, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, 2007. ,
Fast end-to-end trainable guided filter, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, vol.14, p.15, 2018. ,
Image smoothing via L0 gradient minimization, vol.30, pp.174-177, 2011. ,
Structure extraction from texture via relative total variation, ACM Trans Graph, vol.31, issue.6, p.14, 2012. ,
Deep edge-aware filters, Proc. Int. Conf. Machine Learning, 2015. ,
Crossfield joint image restoration via scale map, Proc. Int. Conf, 2013. ,
, Comput. Vis. 1, vol.12, p.13
Saliency detection via graph-based manifold ranking, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, p.12, 2013. ,
Image super-resolution via sparse representation, IEEE Trans Image Process, vol.19, issue.11, pp.2861-2873, 2010. ,
Spatial-depth super resolution for range images, Proc. IEEE Conf. Comput. Vis. Pattern Recognit, 2007. ,
Multi-scale context aggregation by dilated convolutions, Proc. Int. Conf. Learning Representations, vol.7, p.16, 2016. ,
Beyond a Gaussian denoiser: Residual learning of deep CNN for image denoising, IEEE Trans Image Process, vol.26, issue.7, pp.3142-3155, 2017. ,
Rolling guidance filter, Proc. Eur. Conf. Comput. Vis. 1, vol.3, p.13, 2014. ,
Microsoft Kinect sensor and its effect, IEEE Trans Multimedia, vol.19, issue.2, p.10, 2012. ,
, Conditional random fields as recurrent neural networks. In: Proc. Int. Conf. Comput. Vis, p.14, 2015.
