Domain Meissner state and spontaneous vortex-antivortex generation in the ferromagnetic superconductor EuFe 2 (As 0.79 P 0.21 ) 2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science Advances Année : 2018
Nan Zhou
  • Fonction : Auteur
  • PersonId : 1027997
Zhixiang Shi
  • Fonction : Auteur
Xiaofeng Xu
Sunseng Pyon
  • Fonction : Auteur
Yue Sun
  • Fonction : Auteur
Wenhe Jiao
  • Fonction : Auteur
Guang-Han Cao
  • Fonction : Auteur
Lev Ya Vinnikov
  • Fonction : Auteur
The interplay between superconductivity and magnetism is one of the oldest enigmas in physics. Usually, the strong exchange field of ferromagnet suppresses singlet superconductivity via the paramagnetic effect. In EuFe 2 (As 0.79 P 0.21) 2 , a material that becomes not only superconducting at 24.2 K but also ferromagnetic below 19 K, the coexistence of the two antagonistic phenomena becomes possible because of the unusually weak exchange field produced by the Eu subsystem. We demonstrate experimentally and theoretically that when the ferromagnetism adds to superconductivity, the Meissner state becomes spontaneously inhomogeneous, characterized by a nanometer-scale striped domain structure. At yet lower temperature and without any externally applied magnetic field, the system locally generates quantum vortex-antivortex pairs and undergoes a phase transition into a domain vortex-antivortex state characterized by much larger domains and peculiar Turing-like patterns. We develop a quantitative theory of this phenomenon and put forth a new way to realize superconduct-ing superlattices and control the vortex motion in ferromagnetic superconductors by tuning magnetic domains— unprecedented opportunity to consider for advanced superconducting hybrids.
StolyarovSA2018.pdf (1.02 Mo) Télécharger le fichier
hal-01859202 , version 1 (21-08-2018)
Paternité - Pas d'utilisation commerciale
Vasily V Stolyarov, Ivan S Veshchunov, Sergey Yu Grebenchuk, Denis S Baranov, Igor A Golovchanskiy, et al.. Domain Meissner state and spontaneous vortex-antivortex generation in the ferromagnetic superconductor EuFe 2 (As 0.79 P 0.21 ) 2. Science Advances , 2018, 4 (7), pp.eaat1061. ⟨10.1126/sciadv.aat1061⟩. ⟨hal-01859202⟩
268 Consultations
78 Téléchargements
