, (a ? 2, 4) ? C. Consequently a ? 2 sends 1/4 to a ? 1 (by Rule 1) satisfying it and sends 1/2 to a by Rule 2. Finally
, then (a ? 2, 1) ? C or (a ? 2, 4) ? C. If (a ? 2, 2) ? C, then a ? 2 sends 1, vol.2
, (a ? 1, 3)}. Then a ? 1 sends 3/4 to a by Rule 1, so exc 1 (a) = ?1/2. Since C
, Thus (a ? 2, 1), (a ? 2, 4) ? C. In particular, a ? 2 sends 3/4 to a ? 1 by Rule 1, so exc 1 (a ? 1) = ?1/2. Moreover, |C ? Q a?3 | ? 1, for otherwise a ? 3 sends 1/2 to a ? 1 by Rule 2 and 1/4 to a by Rule 3 and a is satisfied
Thus (a ? 2, 1), (a ? 2, 2), (a ? 2, 4) ? C. Moreover |C ? Q a?3 | ? 1 for otherwise a ? 3 sends 1/4 to a ? 2, a ? 1, and a by Rules 1, 2 and 3, respectively, and a is satisfied ,
Thus, (a ? 2, 1), (a ? 2, 3), (a ? 2, 4) ? C. Moreover |C ? Q a?3 | ? 1 for otherwise a ? 3 sends 1/4 to a ? 2, a ? 1, and a by Rules 1, 2 and 3, respectively, and a is satisfied ,
, so either (a ? 2, 1) ? C or (a ? 2, 4) ? C. But |C ? Q a?2 | ? 2 for otherwise a ? 2 sends 5/4 to a ? 1 by Rule 1 and 1/4 to a by Rule 2, and a is satisfied, vol.2
, so either (a?2, 1) ? C or (a?2, 4) ? C. But |C ?Q a?2 | ? 1 for otherwise a?2 sends 1/4 to a?1 by Rule 1 and 1/4 to a by Rule 2, and a is satisfied
, , vol.2
Watching Systems in the King Grid, Graphs and Combinatorics, vol.29, pp.333-347, 2013. ,
Exact minimum density of codes identifying vertices in the square grid, SIAM J. Discrete Math, vol.19, pp.69-82, 2005. ,
Minimum-density identifying codes in square grids, Proceddings of AAIM 2016, vol.9778, pp.77-88, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01259550
Identifying Codes with Small Radius in Some Infinite Regular Graphs, Electronic Journal of Combinatorics, vol.9, p.11, 2002. ,
Improved identifying codes for the grid ,
Bounds for Codes Identifying Vertices in the Hexagonal Grid, SIAM J. Discrete Math, vol.13, pp.492-504, 2000. ,
New bounds for codes identifying vertices in graphs, Electronic Journal of Combinatorics, vol.6, issue.1, p.19, 1999. ,
A new lower bound on the density of vertex identifying codes for the infinite hexagonal grid, Electronic Journal of Combinatorics, vol.16, p.113, 2009. ,
New bounds on the minimum density of an identifying code for the infinite hexagonal graph grid, Discrete Applied Mathematics, vol.161, pp.2910-2924, 2013. ,
Identifying codes in some subgraphs of the square lattice, Theoretical Computer Science, vol.319, pp.411-421, 2004. ,
Identifying codes for infinite triangular grids with a finite number of rows, Discrete Mathematics, vol.340, issue.7, pp.1584-1597, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01358064
A quantitative analysis of secondary rna structure using domination based parameters on trees, BMC Bioinformatics, vol.7, issue.1, p.108, 2006. ,
, Periodicity of identifying codes in strips
On a new class of codes for identifying vertices in graphs, IEEE Trans. Inform. Theory, vol.44, pp.599-611, 1998. ,
Joint monitoring and routing in wireless sensor networks using robust identifying codes, Fourth International Conference on Broadband Communications, Networks and Systems, pp.197-206, 2007. ,
Joint monitoring and routing in wireless sensor networks using robust identifying codes, vol.14, pp.415-432, 2009. ,
Robust location detection in emergency sensor networks, Proceedings IEEE INFOCOM 2003, The 22nd Annual Joint Conference of the IEEE Computer and Communications Societies, 2003. ,
Robust location detection with sensor networks, IEEE Journal on Selected Areas in Communications, vol.22, issue.6, pp.1016-1025, 2004. ,
