GPU-Accelerated Algorithms for Allocating Virtual Infrastructure in Cloud Data Centers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Allocating IT resources to Virtual Infrastructures (VIs) (i.e. groups of VMs, virtual switches, and their network interconnections) is an NP-hard problem. Most allocation algorithms designed to run on CPUs face scalability issues when considering current cloud data centers comprising thousands of servers. This work offers and evaluates a set of allocation algorithms refactored for Graphic Processing Units (GPUs). Experimental results demonstrate their ability to handle three large-scale data center topologies.
ccgrid2018.pdf (149.17 Ko) Télécharger le fichier
hal-01862065 , version 1 (26-08-2018)
Lucas Leandro Nesi, Mauricio Pillon, Marcos Dias de Assuncao, Guilherme Piêgas Koslovski. GPU-Accelerated Algorithms for Allocating Virtual Infrastructure in Cloud Data Centers. CCGRID 2018 - 18th IEEE/ACM International Symposium on Cluster, Cloud and Grid Computing, May 2018, Washington, France. pp.364-365, ⟨10.1109/CCGRID.2018.00057⟩. ⟨hal-01862065⟩
74 Consultations
281 Téléchargements
