Local Stabilization of Analytic Systems with n-1 inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1992
In this communication, we investigate the local stabilization of analytic systems ˙ x = f (x) + Bu with n − 1 inputs. We state a sufficient condition on the first approximation of f for which the local asymptotic stabilizability can be achieved; furthermore, we give explicitly the stabilizing feedback.
IFAC2.pdf (168.92 Ko) Télécharger le fichier
hal-01862881 , version 1 (29-08-2018)
  • HAL Id : hal-01862881 , version 1
Abderrahman Iggidr, Jean-Claude Vivalda. Local Stabilization of Analytic Systems with n-1 inputs. Proc. of the Nonlinear Control Systems Design Symposium NOLCOS'92, Jun 1992, Bordeaux, France. ⟨hal-01862881⟩
39 Consultations
12 Téléchargements
