A-Contrario Horizon-First Vanishing Point Detection Using Second-Order Grouping Laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Gilles Simon
Antoine Fond
We show that, in images of man-made environments, the horizon line can usually be hypothesized based on a-contrario detections of second-order grouping events. This allows constraining the extraction of the horizontal vanishing points on that line, thus reducing false detections. Experiments made on three datasets show that our method, not only achieves state-of-the-art performance w.r.t. horizon line detection on two datasets, but also yields much less spurious vanishing points than the previous top-ranked methods.
1988.pdf (7.58 Mo) Télécharger le fichier
hal-01865251 , version 1 (31-08-2018)
  • HAL Id : hal-01865251 , version 1
Gilles Simon, Antoine Fond, Marie-Odile Berger. A-Contrario Horizon-First Vanishing Point Detection Using Second-Order Grouping Laws. ECCV 2018 - European Conference on Computer Vision, Sep 2018, Munich, Germany. pp.323-338. ⟨hal-01865251⟩
547 Consultations
540 Téléchargements
