Coupling rigid bodies motion with single phase and two-phase compressible flows on unstructured meshes
Abstract : A simple method is developed to couple accurately the motion of rigid bodies to compressible fluid flows. Solid rigid bodies are tracked through a Level-Set function. Numerical diffusion is controlled thanks to a compressive limiter (Overbee) in the frame of MUSCL type scheme, giving an excellent compromise between accuracy and efficiency on unstructured meshes (Chiapolino et al., 2017). The method requires low resolution to preserve solid bodies' volume. Several coupling methods are then addressed to couple rigid body motion to fluid flow dynamics: a method based on stiff relaxation and two methods based on Ghost cells (Fedkiw et al., 1999) and immersed boundaries. Their accuracy and convergence rates are compared against an immersed piston problem in 1D having exact solution. The second Ghost cell method is shown to be the most efficient. It is then extended to multidimensional computations on unstructured meshes and its accuracy is checked against flow computations around blunt bodies. Reference results are obtained when the flow evolves around a rigid body at rest. The same rigid body is then considered with prescribed velocity moving in a flow at rest. Computed results involving wave dynamics match very well. The method is then extended to two-way coupling and illustrated to several examples involving shock wave interaction with solid particles as well as phase transition induced by projectiles motion in liquid-gas mixtures. e-mails:
Complete list of metadatas
Cited literature [30 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-02082701
Contributor : Richard Saurel <>
Submitted on : Thursday, March 28, 2019 - 1:15:22 PM
Last modification on : Wednesday, October 2, 2019 - 1:22:57 AM
Long-term archiving on : Saturday, June 29, 2019 - 2:28:24 PM
File
Couplage_v7.pdf
Identifiers
Citation
Quentin Carmouze, François Fraysse, Richard Saurel, Boniface Nkonga. Coupling rigid bodies motion with single phase and two-phase compressible flows on unstructured meshes. Journal of Computational Physics, Elsevier, 2018, 375, pp.1314-1338. ⟨10.1016/j.jcp.2018.08.023⟩. ⟨hal-02082701⟩
Share
Metrics
Record views
84
Files downloads
95
