A theory of learning from different domains, Machine Learning, vol.79, pp.151-175, 2010. ,
DOI : 10.1007/s10994-009-5152-4
URL : https://link.springer.com/content/pdf/10.1007%2Fs10994-009-5152-4.pdf
Pattern recognition and machine learning, 5th Edition. Information science and statistics, 2007. ,
Extraction of relations between genes and diseases from text and large-scale data analysis: implications for translational research, J. Biomedical Semantics, vol.8, issue.1, p.17, 2015. ,
A shortest path dependency kernel for relation extraction, HLT/EMNLP 2005, Human Language Technology Conference and Conference on Empirical Methods in Natural Language Processing, pp.724-731, 2005. ,
Multitask learning, Machine Learning, vol.28, pp.41-75, 1997. ,
Sequential patterns to discover and characterise biological relations, Computational Linguistics and Intelligent Text Processing, 11th International Conference, pp.537-548, 2010. ,
DOI : 10.1007/978-3-642-12116-6_46
URL : https://hal.archives-ouvertes.fr/hal-01017207
Natural language processing (almost) from scratch, Journal of Machine Learning Research, vol.12, pp.2493-2537, 2011. ,
, , 2017.
Domain adaptation for relation extraction with domain adversarial neural network, Proceedings of the Eighth International Joint Conference on Natural Language Processing, vol.2, pp.425-429, 2017. ,
On handling negative transfer and imbalanced distributions in multiple source transfer learning, Statistical Analysis and Data Mining, vol.7, issue.4, pp.254-271, 2014. ,
Learning task-dependent distributed representations by backpropagation through structure, IEEE International Conference on, vol.1, pp.347-352, 1996. ,
Extraction of potential adverse drug events from medical case reports, Journal of biomedical semantics, vol.3, issue.1, p.15, 2012. ,
Datasets for generic relation extraction, Natural Language Engineering, vol.18, issue.1, pp.21-59, 2012. ,
The DDI corpus: An annotated corpus with pharmacological substances and drug-drug interactions, Journal of Biomedical Informatics, vol.46, issue.5, pp.914-920, 2013. ,
Distributional representations for handling sparsity in supervised sequence-labeling, ACL 2009, Proceedings of the 47th Annual Meeting of the Association for Computational Linguistics and the 4th International Joint Conference on Natural Language Processing of the AFNLP, pp.495-503, 2009. ,
Convolutional neural networks for sentence classification, Proceedings of the 2014 Conference on Empirical Methods in Natural Language Processing, pp.1746-1751, 2014. ,
Word embeddings through hellinger PCA, Proceedings of the 14th Conference of the European Chapter of the Association for Computational Linguistics, pp.482-490, 2014. ,
Joint RNNbased greedy parsing and word composition, 2014. ,
A dependency-based neural network for relation classification, Proceedings of the 53rd Annual Meeting of the Association for Computational Linguistics and the 7th International Joint Conference on Natural Language Processing, vol.2, 2015. ,
Selftraining for biomedical parsing, ACL 2008, Proceedings of the 46th Annual Meeting of the Association for Computational Linguistics, pp.101-104, 2008. ,
Distant supervision for relation extraction without labeled data, Proceedings of the Joint Conference of the 47th Annual Meeting of the ACL and the 4th International Joint Conference on Natural Language Processing of the AFNLP, vol.2, pp.1003-1011, 2009. ,
DOI : 10.3115/1690219.1690287
URL : http://dl.acm.org/ft_gateway.cfm?id=1690287&type=pdf
End-to-end relation extraction using LSTMs on sequences and tree structures, Proceedings of the 54th Annual Meeting of the Association for Computational Linguistics, ACL, 2016. ,
DOI : 10.18653/v1/p16-1105
URL : https://doi.org/10.18653/v1/p16-1105
A. Kors, and Laura Inés Furlong. 2012. The EU-ADR corpus: Annotated drugs, diseases, targets, and their relationships, Journal of Biomedical Informatics, vol.45, issue.5, pp.879-884 ,
URL : https://hal.archives-ouvertes.fr/inserm-00149805
Embedding semantic similarity in tree kernels for domain adaptation of relation extraction, Proceedings of the 51st Annual Meeting of the Association for Computational Linguistics, vol.1, pp.1498-1507, 2013. ,
Multichannel Convolutional Neural Network for Biological Relation Extraction. BioMed research international, p.1850404, 2016. ,
DOI : 10.1155/2016/1850404
URL : http://doi.org/10.1155/2016/1850404
A stochastic approximation method, Herbert Robbins Selected Papers, pp.102-109, 1985. ,
Combating negative transfer from predictive distribution differences, IEEE Trans. Cybernetics, vol.43, issue.4, pp.1153-1165, 2013. ,
DOI : 10.1109/tsmcb.2012.2225102
Parsing with compositional vector grammars, Proceedings of the 51st Annual Meeting of the Association for Computational Linguistics, ACL 2013, pp.455-465, 2013. ,
Dropout: a simple way to prevent neural networks from overfitting, Journal of Machine Learning Research, vol.15, issue.1, pp.1929-1958, 2014. ,
Improved semantic representations from tree-structured long short-term memory networks, Proceedings of the 53rd Annual Meeting of the Association for Computational Linguistics, ACL 2015, pp.1556-1566, 2015. ,
DOI : 10.3115/v1/p15-1150
URL : https://doi.org/10.3115/v1/p15-1150
A survey of transfer learning, J. Big Data, vol.3, p.9, 2016. ,
Semantic relation classification via convolutional neural networks with simple negative sampling, Proceedings of the 2015 Conference on Empirical Methods in Natural Language Processing, pp.536-540, 2015. ,
DOI : 10.18653/v1/d15-1062
URL : https://doi.org/10.18653/v1/d15-1062
A position encoding convolutional neural network based on dependency tree for relation classification, Proceedings of the 2016 Conference on Empirical Methods in Natural Language Processing, pp.65-74, 2016. ,
DOI : 10.18653/v1/d16-1007
URL : https://doi.org/10.18653/v1/d16-1007
Relation classification via convolutional deep neural network, COLING 2014, 25th International Conference on Computational Linguistics, pp.2335-2344, 2014. ,
, Multiple source domain adaptation with adversarial training of neural networks, 2017.
