New interface
Conference papers
Potential effects on server power metering and modeling
Abstract : Cloud datacenters are compute facilities formed by hundreds or even thousands of servers. With the increasing demand of cloud services, energy efficiency of servers in data center has become a significant issue. The knowledge of the energy consumption corresponding to hardware and software configuration is important for operators to optimize energy efficiency of a data center. We currently work on a predictive model for energy consumption of a server, with inputs as service provided, hardware material equipped (type and quantity of processor, memory and hard drive) and technical environment (energy conversion and cooling). In this article, we characterize some potential factors on the power variation of the servers, such as: original fabrication, position in the rack, voltage variation and temperature of components on motherboard. The results show that certain factors, such as original fabrication, ambient temperature and CPU temperature, have noticeable effects on the power consumption of servers. The experimental results emphasize the importance of adding these external factors into the metric, so as to build an energy predictive model adaptable in real situations.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01869705
Contributor : Jean-Marc Menaud Connect in order to contact the contributor
Submitted on : Thursday, September 6, 2018 - 4:04:59 PM
Last modification on : Thursday, November 17, 2022 - 4:48:10 PM
Long-term archiving on: : Friday, December 7, 2018 - 10:21:48 PM
File
cloudcomp2018.pdf
Identifiers
Citation
Yewan Wang, David Nörtershäuser, Stéphane Le Masson, Jean-Marc Menaud. Potential effects on server power metering and modeling. CloudComp 2018 : 8th EAI International Conference on Cloud Computing, Sep 2018, Exeter, United Kingdom. pp.1-12, ⟨10.1007/s11276-018-1882-1⟩. ⟨hal-01869705⟩
Share
Metrics
Record views
233
Files downloads
373
