Stochastic Navigation Function Implementation by a Semi-Analytical Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Logiciel Année : 2018
This repository contains the source code used to produce the results of the following publication (which is currently in print). Isabelle Santos, Stéphane Puechmorel, Guillaume Dufour. First Order Hadamard Variation of the Harmonic Navigation Function on a Sphere World. 2018. 〈hal-01855142〉
Collections
ENAC DEVI ANR
230 Consultations
57 Téléchargements
