Preprints, Working Papers, ...
On the wellposedness of some McKean models with moderated or singular diffusion coefficient
Abstract : We investigate the well-posedness problem related to two models of nonlinear McKean Stochastic Differential Equations with some local interaction in the diffusion term. First, we revisit the case of the McKean-Vlasov dynamics with moderate interaction, previously studied by Meleard and Jourdain in [16], under slightly weaker assumptions, by showing the existence and uniqueness of a weak solution using a Sobolev regularity framework instead of a Holder one. Second, we study the construction of a Lagrangian Stochastic model endowed with a conditional McKean diffusion term in the velocity dynamics and a nondegenerate diffusion term in the position dynamics.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01869951
Contributor : Mireille Bossy Connect in order to contact the contributor
Submitted on : Friday, September 7, 2018 - 8:42:39 AM
Last modification on : Friday, January 21, 2022 - 3:21:00 AM
Links full text
Identifiers
  • HAL Id : hal-01869951, version 1
  • ARXIV : 1809.01742
Citation
Mireille Bossy, Jean Francois Jabir. On the wellposedness of some McKean models with moderated or singular diffusion coefficient. 2018. ⟨hal-01869951⟩
Share
Metrics
Record views
85
