On the Decision Problem for MELL - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2018
(1)
1
In this short paper I will exhibit several mistakes in the recent attempt by Bimbò to prove the decidability of the multiplicative exponential fragment of linear logic (MELL). In fact, the main mistake is so serious that there is no obvious fix, and therefore the decidability of MELL remains to be an open problem. As a side effect, this paper contains a complete (syntactic) proof of the decidability of the relevant version of MELL (called RMELL in this paper), that is the logic obtained from MELL by replacing the linear logic contraction rule by a general unrestricted version of the contraction rule. This proof can also be found (with a small error) in Bimbò's work, and a semantic proof has been given by Okada and Terui.
RR-9203.pdf (676.74 Ko) Télécharger le fichier
Dates and versions
hal-01870148 , version 1 (07-09-2018)
Identifiers
  • HAL Id : hal-01870148 , version 1
Cite
Lutz Strassburger. On the Decision Problem for MELL. [Research Report] 9203, Inria Saclay Ile de France. 2018. ⟨hal-01870148⟩
269 View
397 Download
Share
