3D_Fault_Offsets," a Matlab Code to Automatically Measure Lateral and Vertical Fault Offsets in Topographic Data: Application to San Andreas, Owens Valley, and Hope Faults, J. Geophys. Res. Solid Earth, vol.123, pp.815-835, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01737966
, Number of Tie Points generated in all image pairs with with one or other of the reference images listed in horizontal axis with their ID (from Table 1). The yellow curve shows the distribution of the Tie Point number among the image pairs, while the average, minimum and maximum values are, Figure, vol.10
Systematic morphometric characterization of volcanic edifices using digital elevation models, Geomorphology, vol.136, pp.114-131, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00671050
Analyzing the evolution of the Tessina landslide using aerial photographs and digital elevation models, Geomorphology, vol.54, pp.77-89, 2003. ,
, A new method for the determination of flow directions and upslope areas in grid digital elevation models, Water Resour. Res, vol.33, pp.309-319
Tracking the relationship between changing skyline and population growth of an Indian megacity using earth observation technology, Geocarto Int, vol.32, pp.1421-1435, 2017. ,
Coseismic Deformation from the 1999 Mw 7.1 Hector Mine, California, Earthquake as Inferred from InSAR and GPS Observations, Bull. Seismol. Soc. Am, vol.92, pp.1390-1402, 2002. ,
Mw = 8.8 Maule Earthquake, central Chile, from static and high-rate GPS, InSAR, and broadband teleseismic data, Geophys. Res. Lett, vol.37, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00521725
Tectonic contraction across Los Angeles after removal of groundwater pumping effects, Nature, vol.412, p.812, 2001. ,
Glacier mapping of the Illecillewaet icefield, British Columbia, Canada, using Landsat TM and digital elevation data, Int. J. Remote Sens, vol.20, pp.273-284, 1999. ,
Remote Sensing Technologies for Post-Earthquake damage assessment: a case study on the, Kunamoto Earthquake, vol.14, 2016. ,
The shuttle radar topography mission-a new class of digital elevation models acquired by spaceborne radar, ISPRS J. Photogramm. Remote Sens, vol.57, pp.241-262, 2003. ,
The shuttle radar topography mission, Rev. Geophys, vol.45, 2007. ,
Automated bias-compensation of rational polynomial coefficients of high resolution satellite imagery based on topographic maps, ISPRS J. Photogramm. Remote Sens, vol.100, pp.14-22, 2015. ,
A multi-resolution methodology for the 3D modeling of large and complex archeological areas, Int. J. Archit. Comput, vol.7, pp.39-55, 2009. ,
The evolution of faults formed by shearing across joint zones in sandstone, J. Struct. Geol, vol.26, pp.947-966, 2004. ,
Characterization of strike-slip fault-splay relationships in sandstone, J. Struct. Geol, vol.29, pp.1831-1842, 2007. ,
The evolution of the damage zone with fault growth in sandstone and its multiscale characteristics, J. Geophys. Res. Solid Earth, vol.112, p.12401, 2007. ,
MicMac-a free, open-source solution for photogrammetry, Open Geospatial Data Softw. Stand, vol.2, p.14, 2017. ,
Refined satellite image orientation in the free open-source photogrammetric tools apero/micmac, ISPRS Ann. Photogramm. Remote Sens. Spat. Inf. Sci, vol.3, 2016. ,
A maximum-flow formulation of the n-camera stereo correspondence problem. in Computer Vision, Sixth International Conference on, pp.492-499, 1998. ,
Distinctive image features from scale-invariant keypoints, Int. J. Comput. Vis, vol.60, pp.91-110, 2004. ,
Robust scale-invariant feature matching for remote sensing image registration, IEEE Geosci. Remote Sens. Lett, vol.6, pp.287-291, 2009. ,
Multiple view geometry in computer vision, 2003. ,
A multiresolution and optimization-based image matching approach: An application to surface reconstruction from SPOT5-HRS stereo imagery, Arch. Photogramm. Remote Sens. Spat. Inf. Sci, vol.36, 2006. ,
Fast normalized cross-correlation, Vision interface, vol.10, pp.120-123, 1995. ,
