Quantum Lattice Enumeration and Tweaking Discrete Pruning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Enumeration is a fundamental lattice algorithm. We show how to speed up enumeration on a quantum computer, which affects the security estimates of several lattice-based submissions to NIST: if T is the number of operations of enumeration, our quantum enumeration runs in roughly $√ T$ operations. This applies to the two most efficient forms of enumeration known in the extreme pruning setting: cylinder pruning but also discrete pruning introduced at Eurocrypt '17. Our results are based on recent quantum tree algorithms by Montanaro and Ambainis-Kokainis. The discrete pruning case requires a crucial tweak: we modify the preprocessing so that the running time can be rigorously proved to be essentially optimal, which was the main open problem in discrete pruning. We also introduce another tweak to solve the more general problem of finding close lattice vectors.
QuantumEnum-Eprint18.pdf (752.17 Ko) Télécharger le fichier
hal-01870620 , version 1 (08-09-2018)
  • HAL Id : hal-01870620 , version 1
Yoshinori Aono, Phong Q. Nguyen, Yixin Shen. Quantum Lattice Enumeration and Tweaking Discrete Pruning. Asiacrypt 2018 - the 24th Annual International Conference on the Theory and Application of Cryptology and Information Security, Dec 2018, Brisbane, Australia. ⟨hal-01870620⟩
340 Consultations
401 Téléchargements
