VLSI physical design: from graph partitioning to timing closure, 2011. ,
Placement: Hot or not?, Proc. of ISPD, pp.283-290, 2012. ,
Toward optimal legalization for mixed-cell-height circuit designs, p.52, 2017. ,
Techniques for fast physical synthesis, Proceedings of the IEEE, vol.95, issue.3, pp.573-599, 2007. ,
Method and system for high speed detailed placement of cells within an integrated circuit design, vol.370, p.673, 2002. ,
Abacus: fast legalization of standard cell circuits with minimal movement, 2008. ,
An effective legalization algorithm for mixed-cell-height standard cells, Design Automation Conference (ASP-DAC, pp.450-455, 2017. ,
Detailed placement accounting for technology constraints, 2014 22nd International Conference on, pp.1-6, 2014. ,
Density-aware detailed placement with instant legalization, DAC Proceedings, pp.1-6, 2014. ,
A fast, robust network flow-based standard-cell legalization method for minimizing maximum movement, 2017. ,
A hierarchical bin-based legalizer for standard-cell designs with minimal disturbance, ASP-DAC, 2010 15th Asia and South Pacific, 2010. ,
Diffusion-based placement migration with application on legalization, IEEE TCAD Integr. Circuits Syst, vol.26, issue.12, pp.2158-2172, 2007. ,
VLSI legalization with minimum perturbation by iterative augmentation," in DATE, pp.1385-1390, 2012. ,
Mixed-cell-height standard cell placement legalization, ACM GLSVLSI 2017, 2017. ,
ICCAD-2015 CAD contest in incremental timing-driven placement and benchmark suite ,
Legalization algorithm for multiple-row height standard cell design, 53th Annual Design Automation Conference, pp.1-6, 2016. ,
Multidimensional binary search trees used for associative searching, Commun. ACM, vol.18, issue.9, pp.509-517, 1975. ,
The quadtree and related hierarchical data structures, ACM Computing Surveys (CSUR), vol.16, issue.2, pp.187-260, 1984. ,
ICCAD-2017 CAD contest in multi-deck standard cell legalization and benchmarks, pp.867-871, 2017. ,
, Ophidian: an open source library for physical design research and teaching
OpenMP: an industry standard API for shared-memory programming, IEEE computational science and engineering, 1998. ,
hwloc: A generic framework for managing hardware affinities in hpc applications, Parallel, Distributed and Network-Based Processing (PDP), pp.180-186, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00429889
