On simple scheme of finite/fixed-time control design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2020
Control laws are designed for stabilization of a chain of integrators of arbitrary degree in finite and fixed time. Presented control laws are obtained with use of Lyapunov function method and homogeneity concept. The present analysis is based on use of explicitly defined Lyapunov function that is the hallmark with respect to similar works. This analysis allows to get simple procedure of parameters tuning and obtain new estimates for settling-time function. The theoretical results are supported by numerical examples.
Automatique
IJC_paper.pdf (387.96 Ko) Télécharger le fichier
hal-01872533 , version 1 (12-09-2018)
Konstantin Zimenko, Andrey Polyakov, Denis Efimov, Wilfrid Perruquetti. On simple scheme of finite/fixed-time control design. International Journal of Control, 2020, 93 (6), ⟨10.1080/00207179.2018.1506889⟩. ⟨hal-01872533⟩
Collections
INRIA INRIA2
79 Consultations
340 Téléchargements
