A Software Environment for the Automatic Configuration of Inspections Systems, Proceedings of KBUP'95, pp.99-108, 1995. ,
Automating image processing for scientific data analysis of a large image database, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.18, issue.8, pp.854-859, 1996. ,
A Knowledge-based Approach to the Integration of Image Processing Procedures', Computer Vision, Graphics and Image, vol.57, pp.166-184, 1993. ,
Experiments in Building Program Supervision Engines from Reusable Components, 3th European Conference on Artificial Intelligence Workshop on Applications of Ontologies and Problem-Solving Methods, 1998. ,
UPML: A Framework for Knowledge System Reuse, International Joint Conference on AI (IJCAI-99), 1999. ,
OIL in a Nutshell, EKAW'2000, 12th International Conference on Knowledge Engineering and Knowledge Management, 1935. ,
Knowledge interchange format version 3.0 reference manual, 1992. ,
Composition of Image Analysis Processes Through Object-Centered Hierarchical Planning, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, issue.10, 1995. ,
The COLLAGE/KHOROS Link: Planning for Image Processing Tasks, AAAI Spring Symposium on Integrated Planning Applications, 1995. ,
Solution for a learning configuration system for image processing, 11th International Conference on Industrial Applications of Artificial Intelligence and Expert Systems, 1998. ,
Declarative Workflows that Support Easy Modification and Dynamic Browsing, International Joint Conference on Work Activities Coordination and Collaboration, pp.69-78, 1999. ,
Program Supervision under Resource Constraints, 3th European Conference on Artificial Intelligence Workshop on Monitoring and Control of Real-Time Intelligent Systems, 1998. ,
Towards an Intelligent Failure Handling Mechanism in Program Supervision, Proceedings of KBUP'95, 1995. ,
Representation de connaissances au moyen de classes et d'associations : le système AROM, Langages et Modèles Objets (LMO'00), pp.91-106, 2000. ,
TASK: a framework for the different steps of a KBS construction, Workshop on Knowledge Engineering and Modelling LAnguage (KEML'96, 1996. ,
Experience in Integrating Image Processing Programs, Internatianal Conference on Computer Vision Systems, 1999. ,
DSTM: a Framework to Operationalize and Refine a Problem-Solving Method modeled in terms of Tasks and Methods, International Journal of Expert Systems With Applications, vol.16, issue.2, pp.105-120, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-00278458
Modélisation de Connaissances pour le Pilotage de Programmes de Traitement d'Images, 1996. ,
Modelling Software Components for Reuse, Seventh International Conference on Software Engineering and Knowledge Engineering, pp.350-357, 1995. ,
