On the construction of general cubature formula by flat extensions, Linear Algebra Appl, vol.502, pp.104-125, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01158099
The classical moment problem and some related questions in analysis, 1965. ,
Sylvester's identity and multistep integer-preserving Gaussian elimination, Math. Comp, vol.22, pp.565-578, 1968. ,
Computational solutions of matrix problems over an integral domain, J. Inst. Math. Appl, vol.10, pp.68-104, 1972. ,
Algorithms in real algebraic geometry, Algorithms and Computation in Mathematics, vol.10, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01083587
The proof of Tchakaloff's theorem, Proc. Amer. Math. Soc, vol.134, issue.10, pp.3035-3040, 2006. ,
How to choose modified moments?, J. Comput. Appl. Math, vol.98, issue.1, pp.81-98, 1998. ,
A deterministic algorithm for sparse multivariate polynomial interpolation, Proceedings of the Twentieth Annual ACM Symposium on Theory of Computing, STOC '88, pp.301-309, 1988. ,
Real algebraic geometry, Ergebnisse der Mathematik und ihrer Grenzgebiete, vol.36, issue.3 ,
Translated from the 1987 French original, Revised by the authors, 1998. ,
Symmetric tensor decomposition, Linear Algebra Appl, vol.433, pp.1851-1872, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00355713
, Sparse grids, vol.13, pp.147-269, 2004.
Numerical reconstruction of convex polytopes from directional moments, Advances in Computational Mathematics, pp.1-21, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00926357
Cubatures with symmetry. In preparation, 2018. ,
Constructing cubature formulae: the science behind the art, Acta numerica, vol.6, pp.1-54, 1997. ,
Cubature formulae and orthogonal polynomials, J. Comput. Appl. Math, vol.127, issue.1-2, pp.121-152, 2000. ,
Monomial cubature rules since "Stroud": a compilation, J. Comput. Appl. Math, vol.48, issue.3, pp.309-326, 1993. ,
Using algebraic geometry, volume 185 of Graduate Texts in Mathematics, 2005. ,
Solution of the truncated complex moment problem for flat data, Mem. Amer. Math. Soc, vol.119, issue.568, p.52, 1996. ,
The truncated complex K-moment problem, Trans. Amer. Math. Soc, vol.352, issue.6, pp.2825-2855, 2000. ,
A construction of nonnegative approximate quadratures, Math. Comp, vol.21, pp.578-582, 1967. ,
Orthogonal polynomials of several variables, of Encyclopedia of Mathematics and its Applications, vol.81, 2001. ,
Shape from moments-an estimation theory perspective, IEEE Trans. Signal Process, vol.52, issue.7, pp.1814-1829, 2004. ,
A moment matrix approach to multivariable cubature. Integral Equations Operator Theory, vol.52, pp.85-124, 2005. ,
Convolution surfaces with varying radius: Formulae for skeletons made of arcs of circles and line segments, 2018. ,
Algorithms for computer algebra, 1992. ,
Symbolic-numeric sparse interpolation of multivariate polynomials, J. Symbolic Comput, vol.44, issue.8, pp.943-959, 2009. ,
DOI : 10.1145/1145768.1145792
URL : http://www.cecm.sfu.ca/~pborwein/MITACS/papers/wenshin.pdf
Matrices, moments and quadrature with applications, Princeton Series in Applied Mathematics, 2010. ,
DOI : 10.1515/9781400833887
A stable numerical method for inverting shape from moments, SIAM J. Sci. Comput, vol.21, issue.4, p.0, 1999. ,
DOI : 10.1137/s1064827597328315
The Inverse Moment Problem for Convex Polytopes, Discrete Comput. Geom, vol.48, issue.3, pp.596-621, 2012. ,
DOI : 10.1007/s00454-012-9426-4
URL : https://link.springer.com/content/pdf/10.1007%2Fs00454-012-9426-4.pdf
Die Grundlehren der Mathematischen Wissenschaften, vol.97, 1967. ,
Power series-integration-conformal mapping-location of zeros, vol.1, 1988. ,
Exact algorithms for linear matrix inequalities, SIAM J. Optim, vol.26, issue.4, pp.2512-2539, 2016. ,
DOI : 10.1137/15m1036543
URL : https://hal.archives-ouvertes.fr/hal-01184320
Exact division applied to diagonalizing symmetric matrices, 1994. ,
Convolution surfaces based on polygons for infinite and compact support kernels, Graphical Models, vol.74, issue.1, pp.1-13, 2012. ,
DOI : 10.1016/j.gmod.2011.07.001
URL : https://hal.archives-ouvertes.fr/inria-00536840
Convolution Surfaces based on Polygonal Curve Skeletons. (An Application of Symbolic Integration to Graphics), Journal of Symbolic Computation, vol.47, issue.6, pp.680-699, 2012. ,
DOI : 10.1016/j.jsc.2011.12.026
URL : https://hal.archives-ouvertes.fr/inria-00429358
Efficient quadrature for nurbs-based isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5-8, pp.301-313, 2010. ,
DOI : 10.1016/j.cma.2008.12.004
Improved sparse multivariate polynomial interpolation algorithms, Symbolic and algebraic computation, vol.358, pp.467-474, 1988. ,
DOI : 10.1007/3-540-51084-2_44
Early termination in sparse interpolation algorithms, International Symposium on Symbolic and Algebraic Computation (ISSAC'2002, vol.36, pp.365-400, 2003. ,
DOI : 10.1016/s0747-7171(03)00088-9
URL : https://doi.org/10.1016/s0747-7171(03)00088-9
A multivariate generalization of prony's method, 2015. ,
DOI : 10.1016/j.laa.2015.10.023
URL : http://arxiv.org/pdf/1506.00450
Global optimization with polynomials and the problem of moments, SIAM J. Optim, vol.11, issue.3, p.1, 2000. ,
Moments, positive polynomials and their applications, vol.1, 2010. ,
DOI : 10.1142/p665
The existence of Gaussian cubature formulas, J. Approx. Theory, vol.164, issue.5, pp.572-585, 2012. ,
Revisiting two theorems of Curto and Fialkow on moment matrices, Proc. Amer. Math. Soc, vol.133, issue.10, pp.2965-2976, 2005. ,
Sums of squares, moment matrices and optimization over polynomials, Emerging applications of algebraic geometry, vol.149, pp.157-270, 2009. ,
DOI : 10.1007/978-0-387-09686-5_7
URL : http://homepages.cwi.nl/~monique/files/moment-ima.pdf
A generalized flat extension theorem for moment matrices, Arch. Math. (Basel), vol.93, issue.1, pp.87-98, 2009. ,
DOI : 10.1007/s00013-009-0007-6
URL : http://www.cwi.nl/~monique/files/archivlm.pdf
, Spectral methods for uncertainty quantification. Scientific Computation, 2010.
Discrete Fourier analysis, cubature, and interpolation on a hexagon and a triangle, SIAM J. Numer. Anal, vol.46, issue.4, pp.1653-1681, 2008. ,
DOI : 10.1137/060671851
URL : http://arxiv.org/pdf/0712.3093
Quadrature rules for regions having regular hexagonal symmetry, SIAM J. Numer. Anal, vol.14, issue.2, pp.283-295, 1977. ,
DOI : 10.1137/0714018
A certificate for semidefinite relaxations in computing positive-dimensional real radical ideals, J. Symbolic Comput, vol.72, pp.1-20, 2016. ,
DOI : 10.1016/j.jsc.2014.12.002
Cartan involutiveness = Mumford regularity, Commutative algebra, vol.331, pp.193-205, 2001. ,
DOI : 10.1090/conm/331/05911
Systèmes différentiels involutifs, volume 19 of Panoramas et Synthèses ,
, , 2005.
Matrix generation in isogeometric analysis by low rank tensor approximation, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01084421
Reconstructing polygons from moments with connections to array processing, IEEE Transactions on Signal Processing, vol.43, pp.432-443, 1995. ,
Lower bounds for the number of nodes in cubature formulae, In Numerische Integration (Tagung, Math. Forschungsinst, vol.45, pp.221-230, 1978. ,
Polynomial exponential decomposition from moments, Found. Comput. Math, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01367730
Parameter estimation for exponential sums by approximate prony method, Signal Processing, vol.90, issue.5, pp.1631-1642, 2010. ,
Parameter estimation for multivariate exponential sums, Electron. Trans. Numer. Anal, vol.40, pp.204-224, 2013. ,
A note on Tchakaloff's theorem, Proc. Amer. Math. Soc, vol.125, issue.8, pp.2409-2414, 1997. ,
, Zur mechanischen Kubatur. Monatsh. Math, vol.52, pp.286-300, 1948.
Baron de Prony) Riche. Essai expérimental et analytique sur les lois de la dilatabilité des fluidesélastique fluidesélastique et sur celles de la force expansive de la vapeur de l'eau et de la vapeur de l'alkool, ` a différentes températures, J. de l' ´ Ecole Polytechnique, vol.1, pp.24-76, 1795. ,
Parameterfreie Abschätzung und Realisierung von Erwartungswerten, Bl. Deutsch. Ges. Versicherungsmath, vol.3, pp.147-162, 1957. ,
Optimization approaches to quadrature: new characterizations of Gaussian quadrature on the line and quadrature with few nodes on plane algebraic curves, on the plane and in higher dimensions, J. Complexity, vol.45, pp.22-54, 2018. ,
Convex analysis, Princeton Mathematical Series, issue.28, 1970. ,
Formules de Bareiss et réduction de formes quadratiques, C. R. Acad. Sci. Paris Sér. I Math, vol.320, issue.10, pp.1273-1277, 1995. ,
An algorithm for Gaussian quadrature given modified moments, Numer. Math, vol.18, pp.465-478 ,
Prony's method in several variables: symbolic solutions by universal interpolation, J. Symbolic Comput, vol.84, pp.95-112, 2018. ,
On bivariate Gaussian cubature formulae, Proc. Amer. Math. Soc, vol.122, issue.3, pp.833-841, 1994. ,
The moment problem, Graduate Texts in Mathematics, vol.277, 2017. ,
Introduction to numerical analysis, Texts in Applied Mathematics, vol.12, 2002. ,
Approximate calculation of multiple integrals, 1971. ,
Sur une extension du théorème de clebsch relatif aux courbes duquatrì eme degré. Comptes rendus hebdomadiares des séances de l'Académie des sciences, vol.102, p.1886 ,
Orthogonal polynomials, 1975. ,
Formules de cubatures mécaniquesmécaniquesà coefficients non négatifs, Bull. Sci. Math, vol.81, issue.2, pp.123-134, 1957. ,
Matrix theory ,
