, SIL extensions default declaration
ATTLIST sil type (%SIL.x.a; workspace | user | query | resultset ,
, <!-validated by the Silfide server admin
, >Français</attr><attr name="size">86057</attr></record> <record sid="nancy" idno="FRW3"><attr name="title">Histoire Romaine</ attr><attr name="author">Michelet, Jules</attr><attr name="language">Français</ attr><attr name="size">144022 </attr></record> <record sid="nancy" idno="FRW4"><attr name="title">Récits des temps mérovingiens</attr><attr name="author">Thierry, Augustin</attr><attr name="language">Français</attr><attr name="size">90232</attr></record> <record sid="nancy" idno="FRW5"><attr name="title">Sous les tilleuls</ attr><attr name="author">Karr, Alphonse</attr><attr name="language">Français</ attr><attr name="size">140807</attr></record> <record sid="nancy" idno="FRW6"><attr name="title">Le parfum de la dame en noir</attr><attr name="author">Leroux, Gaston</attr><attr name="language">Français</attr><attr name="size">124157</attr></record> <record sid="nancy" idno="FRW7"><attr name="title">Le Père Goriot</ attr><attr name="author">Balzac, Honoré de .</attr><attr name="language">Français</attr><attr name="size">309234</attr></record> <record sid="nancy" idno="FRW8"><attr name="title">Contes cruels</attr><attr name="author, Léon</attr><attr name="language">Français</ attr><attr name="size">141201</attr></record> <record sid="nancy" idno="FRW2"><attr name="title">Mademoiselle de la Seigliere</attr><attr name="author">Sandeau, Jules</attr><attr name="language
, ElanResultSetImpl rsp = new ElanResultSetImpl(new Meta(
, // sets the total number of documents matching the query rsp.setTotalSize(NB_RESOURCES)
, // add each individual documents references to the result set for
, // add a document (sid+idno) + a list of display attributes rsp.addRecord(sid,getIdno(),null,getNewResource()); (sessionID, Integer(cpt)
, !=null) queries.put(sessionID,eq)
, Hashtable corpora = new Hashtable(
, rsp.addRecord(sid,"allCorpora
, sessions.put(sessionID,new Integer(cpt))
, * perform a new query with an associated basket
, // instanciation of a reader to read the basket string sequentially StringReader sr = new StringReader
, // creation of an XML Document corresponding to the XML string Document sbd = loader.loadDocument(sr)
, // extraction of the root element from the basket document Element sbe = sbd
, // parsing of the basket element Basket sb = SILBasket.process(sbe)
, // extraction of the basket resources for
, String r_sid = r.getSid(
, // verify if the resource is on this local server { String idno = r
, } Integer icpt = new Integer, issue.0
, sessions.put(sessionID,icpt)
, NB_RESOURCES
, Hashtable htres = new Hashtable(
addRecord(sid,getIdno(),qh+" "+sessionID+ ,
, htres
, htres.clear(
