Implementation of loop-shaping compensators to increase the transparency bandwidth of a scaled telemanipulation system, Proc.IEEE International Conference on Robotics and Automation, vol.3, pp.2886-2893, 2002. ,
Stability and transparency in bilateral teleoperation, IEEE Transactions on Robotics and Automation, vol.9, pp.624-637, 1993. ,
DOI : 10.1109/cdc.1992.371336
Haptic rendering: Programming touch interaction with virtual objects, Proc. Symposium on Interactive 3D graphics, pp.123-130, 1995. ,
Transparency enhancement of haptic interface using model matching approach, Proc. Indian Control Conference, pp.399-404, 2016. ,
DOI : 10.1109/indiancc.2016.7441165
A tactile shape display using RC servomotors, Proc. Symposium on Haptic Interfaces for Virtual Environment and Teleoperator Systems, pp.354-355, 2002. ,
DOI : 10.1109/haptic.2002.998981
Objective surgical performance evaluation based on haptic feedback, Studies in Health Technology and Informatics, vol.85, pp.304-310, 2002. ,
Enhancing the Performance of Passive Teleoperation Systems via Cutaneous Feedback, IEEE Transactions on Haptics, vol.8, pp.397-409, 2015. ,
DOI : 10.1109/toh.2015.2457927
Experimental evaluation of magnified haptic feedback for robot-assisted needle insertion and palpation, The International Journal of Medical Robotics and Computer Assisted Surgery, vol.13, 2017. ,
DOI : 10.1002/rcs.1809
URL : https://hal.archives-ouvertes.fr/hal-01482249
Dissipative systems analysis and control, 2000. ,
DOI : 10.1007/978-1-4471-3668-2
URL : https://hal.archives-ouvertes.fr/hal-00821748
L2-Gain and Passivity Techniques in Nonlinear Control, Communications and Control Engineering, 2000. ,
Stable teleoperation with time-domain passivity control, IEEE Transactions on Robotics and Automation, vol.20, pp.365-373, 2004. ,
DOI : 10.1109/tra.2004.824689
URL : http://rcs.ee.washington.edu/BRL/publications/Rep154.pdf
Time-domain passivity control of haptic interfaces, IEEE Transactions on Robotics and Automation, vol.18, pp.1-10, 2002. ,
DOI : 10.1109/70.988969
URL : http://robot.kaist.ac.kr/~ryujh/ICRA01-2.pdf
Telemanipulation with Time Delays, The International Journal of Robotics Research, vol.23, pp.873-890, 2004. ,
DOI : 10.1177/0278364904045563
URL : http://journals.sagepub.com/doi/pdf/10.1177/0278364904045563
Robustly Stable Haptic Interaction Control using an Energy-bounding Algorithm, The International Journal of Robotics Research, vol.29, pp.666-679, 2010. ,
DOI : 10.1177/0278364909338770
Sampled-and continuoustime passivity and stability of virtual environments, IEEE Transactions on Robotics, vol.20, pp.772-776, 2004. ,
DOI : 10.1109/tro.2004.829453
URL : http://brl.ee.washington.edu/publications/Rep180.pdf
Time domain passivity control with reference energy following, IEEE Transactions on Control Systems Technology, vol.13, pp.737-742, 2005. ,
Bilateral Telemanipulation With Time Delays: A Two-Layer Approach Combining Passivity and Transparency, IEEE Transactions on Robotics, vol.27, pp.741-756, 2011. ,
DOI : 10.1109/tro.2011.2142430
A tank-based approach to impedance control with variable stiffness, 2013 IEEE International Conference on Robotics and Automation (ICRA), pp.4948-4953, 2013. ,
DOI : 10.1109/icra.2013.6631284
Optimizing the use of power in wave based bilateral teleoperation, 2016 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), pp.1469-1474, 2016. ,
Bridging the gap between passivity and transparency, Proc. Robotics: Science and Systems, 2009. ,
DOI : 10.15607/rss.2009.v.036
URL : https://doi.org/10.15607/rss.2009.v.036
Controlling impedance at the man/machine interface, Proc. International Conference on Robotics and Automation, vol.3, pp.1626-1631, 1989. ,
DOI : 10.1109/robot.1989.100210
A survey of computational complexity results in systems and control, Automatica, vol.36, issue.9, pp.1249-1274, 2000. ,
qpOASES: A parametric active-set algorithm for quadratic programming, Mathematical Programming Computation, vol.6, issue.4, pp.327-363, 2014. ,
DOI : 10.1007/s12532-014-0071-1
Analysis of variance, 1987. ,
Tests of sphericity of normal distributions and the analysis of repeated measures designs, Psychometrika, vol.49, issue.2, pp.257-267, 1984. ,
