, , 2018.
, , 2018.
, , 2018.
Code reuse in open source software development: Quantitative evidence, drivers, and impediments, 2010. ,
, Node.js 8: Big Improvements for the Debugging and Native Module Ecosystem, 2018.
Faust audio DSP language in the Web, Proceedings of the Linux Audio Conference (LAC-15), 2015. ,
Write once run anywhere revisited: machine learning and audio tools in the browser with C++ and emscripten, 2017. ,
The seamless peer and cloud evolution framework, Proceedings of the Genetic and Evolutionary Computation Conference, pp.821-828, 2016. ,
Rust as a language for high performance GC implementation, Proceedings of the 2016 ACM SIGPLAN International Symposium on Memory Management, pp.89-98, 2016. ,
What can the programming language Rust do for astrophysics, Proceedings of the International Astronomical Union, vol.12, issue.S325, pp.341-344, 2016. ,
Proximity: A real-time, location aware social web application built with Node.js and AngularJS, International Conference on Mobile Web and Information Systems, pp.292-295, 2013. ,
Is Node.js a viable option for building modern web applications? A performance evaluation study, Computing Springer, issue.10, pp.1023-1044, 2015. ,
The GPM meta-transcompiler: Harmonizing JavaScript-oriented Web development with the upcoming ECMAScript 6 "Harmony" specification, 12th Annual IEEE Consumer Communications and Networking Conference (CCNC), pp.176-181, 2015. ,
Popularity, interoperability, and impact of programming languages in 100,000 open source projects, Computer Software and Applications Conference (COMPSAC), pp.303-312, 2013. ,
JavaScript: The Good Parts: The Good Parts, 2008. ,
Efficient and thread-safe objects for dynamically-typed languages, Proceedings of the 2016 ACM SIGPLAN International Conference on Object-Oriented Programming, Systems, Languages, and Applications, pp.642-659, 2016. ,
, Addons Node.js, 2018.
, , 2018.
, , 2018.
, GYP, 2018.
Improving the build architecture of legacy C/C++ software systems, International Conference on Fundamental Approaches to Software Engineering, pp.96-110, 2005. ,
, , 2018.
, , 2018.
Understanding integer overflow in C/C++, ACM Transactions on Software Engineering and Methodology (TOSEM), vol.25, issue.1, 2015. ,
C: From Theory to Practice, 2017. ,
Abstraction and the C++ machine model, International Conference on Embedded Software and Systems, pp.1-13, 2004. ,
Rust for functional programmers, 2014. ,
, The Rust Programming Language, 2018.
Emscripten: an LLVM-to-JavaScript compiler, Proceedings of the ACM international conference companion on Object oriented programming systems languages and applications companion, pp.301-312, 2011. ,
WebAssembly: high speed at low cost for everyone, ML16: Proceedings of the 2016 ACM SIGPLAN Workshop on ML. 40. Oxidizing Source Maps with Rust and WebAssembly, 2016. ,
, , 2018.
