Secure Distributed Computing on Untrusted Fog Infrastructures Using Trusted Linux Containers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Fog and Edge computing provide a large pool of resources at the edge of the network that may be used for distributed computing. Fog infrastructure heterogeneity also results in complex configuration of distributed applications on computing nodes. Linux containers are a mainstream technique allowing to run packaged applications and micro services. However, running applications on remote hosts owned by third parties is challenging because of untrusted operating systems and hardware maintained by third parties. To meet such challenges, we may leverage trusted execution mechanisms. In this work, we propose a model for distributed computing on Fog infrastructures using Linux containers secured by Intel’s Software Guard Extensions (SGX) technology. We implement our model on a Docker and OpenSGX platform. The result is a secure and flexible approach for distributed computing on Fog infrastructures.
PID5602277.pdf (232.27 Ko) Télécharger le fichier
hal-01875777 , version 1 (15-10-2018)
hal-01875777 , version 2 (16-10-2018)
  • HAL Id : hal-01875777 , version 1
Mohammad-Mahdi Bazm, Marc Lacoste, Mario Südholt, Jean-Marc Menaud. Secure Distributed Computing on Untrusted Fog Infrastructures Using Trusted Linux Containers. CloudCom 2018 - 10th IEEE International Conference on Cloud Computing Technology and Science, Dec 2018, Nicosia, Cyprus. pp.4. ⟨hal-01875777v1⟩
466 Consultations
731 Téléchargements
