Multifidelity Dimension Reduction via Active Subspaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2020
We propose a multifidelity dimension reduction method to identify a low-dimensional structure present in many engineering models. The structure of interest arises when functions vary primarily on a low-dimensional subspace of the high-dimensional input space, while varying little along the complementary directions. Our approach builds on the gradient-based methodology of active subspaces, and exploits models of different fidelities to reduce the cost of performing dimension reduction through the computation of the active subspace matrix. We provide a non-asymptotic analysis of the number of gradient evaluations sufficient to achieve a prescribed error in the active subspace matrix, both in expectation and with high probability. We show that the sample complexity depends on a notion of intrinsic dimension of the problem, which can be much smaller than the dimension of the input space. We illustrate the benefits of such a multifidelity dimension reduction approach using numerical experiments with input spaces of up to three thousand dimensions.
hal-01875946 , version 1 (18-09-2018)
Rémi Lam, Olivier Zahm, Youssef Marzouk, Karen Willcox. Multifidelity Dimension Reduction via Active Subspaces. SIAM Journal on Scientific Computing, 2020, 42 (2), pp.A929-A956. ⟨10.1137/18M1214123⟩. ⟨hal-01875946⟩
158 Consultations
0 Téléchargements
