Advances in membrane distillation for water desalination and purification applications, Water, vol.5, issue.1, pp.94-196, 2013. ,
Performance evaluation of the dcmd desalination process under bench scale and large scale module operating conditions, Journal of Membrane Science, vol.455, pp.103-112, 2014. ,
Membrane distillation process modeling: Dynamical approach, Nuclear, Metallurgical and Materials Engineering, vol.8, issue.6, pp.479-484, 2014. ,
Water Desalination by Membrane Distillation, Desalination, Trends and Technologies, 2011. ,
Analysis of direct contact membrane distillation based on a lumpedparameter dynamic predictive model, Desalination, vol.402, pp.50-61, 2017. ,
Dynamic modeling and experimental validation for direct contact membrane distillation (DCMD) process, Desalination, vol.384, pp.1-11, 2016. ,
Reduced-Order Dynamic Modeling, Fouling Detection, and Optimal Control of Solar-Powered Direct Contact Membrane Distillation, 2016. ,
Dynamic Modeling and Control of Distributed Heat Transfer Mechanisms: Application to a Membrane Distillation Module, 2015. ,
Control of a reverse osmosis desalination process at high recovery, pp.2241-2247, 2008. ,
Optimal control of a reverse osmosis desalination plant using multi-objective optimization, pp.1368-1373, 2006. ,
Model predictive control of feed flow reversal in a reverse osmosis desalination process, pp.4860-4867, 2009. ,
Backstepping observers for linear pdes on higher-dimensional spatial domains, Automatica, vol.51, pp.85-97, 2015. ,
DOI : 10.1016/j.automatica.2014.10.108
Advanced Membrane Technology and Applications, 2008. ,
Observation and control for operator semigroups, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00590673
