A new family of one dimensional martingale couplings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Journal of Probability Année : 2020
In this paper, we exhibit a new family of martingale couplings between two one-dimensional probability measures μ and ν in the convex order. This family is parametrised by two dimensional probability measures on the unit square with respective marginal densities proportional to the positive and negative parts of the difference between the quantile functions of μ and ν. It contains the inverse transform martingale coupling which is explicit in terms of the quantile functions of these marginal densities. The integral of |x−y| with respect to each of these couplings is smaller than twice the W1 distance between μ and ν. When the comonotonous coupling between μ and ν is given by a map T, the elements of the family minimise ∫R|y−T(x)|M(dx,dy) among all martingale couplings between μ and ν. When μ and ν are in the decreasing (resp. increasing) convex order, the construction is generalised to exhibit super (resp. sub) martingale couplings.
hal-01876809 , version 1 (18-09-2018)
Benjamin Jourdain, William Margheriti. A new family of one dimensional martingale couplings. Electronic Journal of Probability, 2020, 25 (136), pp.1-50. ⟨10.1214/20-EJP543⟩. ⟨hal-01876809⟩
140 Consultations
0 Téléchargements
