?. ?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-?-references,
M. R. Garey and D. S. Johnson, Computers and Intractability, a Guide to the Theory of NP-Completeness, 1979.
D. Borthakur, HDFS Architecture Guide, p.39, 2008.
M. Zaharia, D. Borthakur, J. Sen, K. Sarma, S. Elmeleegy et al., Delay Scheduling: A Simple Technique for Achieving Locality and Fairness in Cluster Scheduling, European Conference on Computer Systems (EuroSys), pp.265-278, 2010.
Q. Xie and Y. Lu, Degree-Guided Map-Reduce Task Assignment with Data Locality Constraint, International Symposium on Information Theory (ISIT), pp.985-989, 2012.
M. Isard, V. Prabhakaran, J. Currey, U. Wieder, K. Talwar et al., Quincy: Fair Scheduling for Distributed Computing Clusters, Symposium on Operating Systems Principles (SOSP, pp.261-276, 2009.
S. Ibrahim, H. Jin, L. Lu, B. He, G. Antoniu et al., Maestro: Replica-Aware Map Scheduling for MapReduce, International Symposium on Cluster, Cloud and Grid Computing (CCGrid), pp.435-442, 2012.
URL : https://hal.archives-ouvertes.fr/hal-00670813
M. Raab and A. Steger, Balls into Bins: A Simple and Tight Analysis, Randomization and Approximation Techniques in Computer Science (RANDOM), pp.159-170, 1998.
P. Berenbrink, T. Friedetzky, Z. Hu, and R. Martin, On weighted Ballsinto-Bins Games, Theoretical Computer Science (TCS), vol.409, issue.3, pp.511-520, 2008.
M. Mitzenmacher, The Power of Two Choices in Randomized Load Balancing, Transactions on Parallel and Distributed Systems (TPDS), vol.12, pp.1094-1104, 2001.
A. W. Richa, M. Mitzenmacher, and R. Sitaraman, The Power of Two Random Choices: A Survey of Techniques and Results, Combinatorial Optimization, vol.9, pp.255-304, 2001.
P. Berenbrink, A. Czumaj, A. Steger, and B. Vöcking, Balanced Allocations: The Heavily Loaded Case, Symposium on Theory of Computing (STOC), pp.745-754, 2000.
Y. Peres, K. Talwar, and U. Wieder, The (1+ ?)-Choice Process and Weighted Balls-into-Bins, Symposium on Discrete Algorithms (SODA). SIAM, pp.1613-1619, 2010.
A. Giersch, Y. Robert, and F. Vivien, Scheduling tasks sharing files from distributed repositories, Proceedings of the 10th International Euro-Par Conference, pp.246-253, 2004.
URL : https://hal.archives-ouvertes.fr/hal-00807284
K. Kaya, B. Uçar, and C. Aykanat, Heuristics for scheduling filesharing tasks on heterogeneous systems with distributed repositories, J. Parallel Distrib. Comput, vol.67, issue.3, pp.271-285, 2007.
URL : https://hal.archives-ouvertes.fr/hal-00803511
H. Casanova, A. Legrand, D. Zagorodnov, and F. Berman, Heuristics for scheduling parameter sweep applications in grid environments, 9th Heterogeneous Computing Workshop, pp.349-363, 2000.
URL : https://hal.archives-ouvertes.fr/hal-00748942
M. Mitzenmacher and E. Upfal, Probability and Computing-Randomized Algorithms and Probabilistic Analysis, 2005.
T. Lambert, On the Effect of Replication of Input Files on the Efficiency and the Robustness of a Set of Computations, 2017.
URL : https://hal.archives-ouvertes.fr/tel-01661588
S. Kavulya, J. Tan, R. Gandhi, and P. Narasimhan, An Analysis of Traces from a Production MapReduce Cluster, International Conference on Cluster, Cloud and Grid Computing (CCGrid), pp.94-103, 2010.
