KafKa: Gradual Typing for Objects
A wide range of gradual type systems have been proposed, providing many languages with the ability to mix typed and untyped code. However, hiding under language details, these gradual type systems embody fundamentally different ideas of what it means to be well-typed. In this paper, we show that four of the most common gradual type systems provide distinct guarantees, and we give a formal framework for comparing gradual type systems for object-oriented languages. First, we show that the different gradual type systems are practically distin-guishable via a three-part litmus test. We present a formal framework for defining and comparing gradual type systems. Within this framework, different gradual type systems become translations between a common source and target language, allowing for direct comparison of semantics and guarantees.
Langage de programmation [cs.PL]
