χ-bounded families of oriented graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Graph Theory Année : 2018
A famous conjecture of Gyárfás and Sumner states for any tree T and integer k, if the chromatic number of a graph is large enough, either the graph contains a clique of size k or it contains T as an induced subgraph. We discuss some results and open problems about extensions of this conjecture to oriented graphs. We conjecture that for every oriented star S and integer k, if the chromatic number of a digraph is large enough, either the digraph contains a clique of size k or it contains S as an induced subgraph. As an evidence, we prove that for any oriented star S, every oriented graph with sufficiently large chromatic number contains either a transitive tournament of order 3 or S as an induced subdigraph. We then study for which sets $P$ of orientations of $P_4$ (the path on four vertices) similar statements hold. We establish some positive and negative results.
Induced-digraphs-revised.pdf (247.24 Ko) Télécharger le fichier
hal-01882395 , version 1 (21-12-2018)
Pierre Aboulker, Jørgen Bang-Jensen, Nicolas Bousquet, Pierre Charbit, Frédéric Havet, et al.. χ-bounded families of oriented graphs. Journal of Graph Theory, 2018, 89 (3), pp.304 - 326. ⟨10.1002/jgt.22252⟩. ⟨hal-01882395⟩
222 Consultations
139 Téléchargements
