Reference SKOS and TBX vocabularies used for comparing the two standards
The present document is a compilation of the SKOS vocabulary and TBX-default data categories used for an ongoing research on the comparison between the SKOS and TBX data models. Nonetheless, the list are derived from [W3C 2009a] and [W3C 2009b] for SKOS and a combination of [ISO 30042] and [LTAC 2018] for TBX.
2018-09-30-terminology-skos-tbx-references-v2.pdf (263.36 Ko)
Télécharger le fichier
