Recycling bicgstab with an application to parametric model order reduction, SIAM Journal on Scientific Computing, vol.37, issue.5, pp.429-446, 2015. ,
Krylov-subspace recycling via the pod-augmented conjugate-gradient method, SIAM Journal on Matrix Analysis and Applications, vol.37, issue.3, pp.1304-1336, 2016. ,
A flexible generalized conjugate residual method with inner orthogonalization and deflated restarting, SIAM Journal on Matrix Analysis and Applications, vol.32, issue.4, pp.1212-1235, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00650239
Tenth spe comparative solution project : A comparison of upscaling techniques, 2001. ,
Nested krylov methods based on gcr, Journal of Computational and Applied Mathematics, vol.67, issue.1, pp.15-41, 1996. ,
Truncation strategies for optimal krylov subspace methods, SIAM Journal on Numerical Analysis, vol.36, issue.3, pp.864-889, 1999. ,
Reverse communication interface for linear algebra templates for iterative methods, 1995. ,
Variational iterative methods for nonsymmetric systems of linear equations, SIAM Journal on Numerical Analysis, vol.20, issue.2, pp.345-357, 1983. ,
Restarted GMRES preconditioned by deflation, Journal of Computational and Applied Mathematics, vol.69, issue.2, pp.303-318, 1996. ,
Deflation and balancing preconditioners for krylov subspace methods applied to nonsymmetric matrices, SIAM Journal on Matrix Analysis and Applications, vol.30, issue.2, pp.684-699, 2008. ,
On the construction of deflation-based preconditioners, SIAM Journal on Scientific Computing, vol.23, issue.2, pp.442-462, 2001. ,
A framework for deflated and augmented krylov subspace methods, SIAM Journal on Matrix Analysis and Applications, vol.34, issue.2, pp.495-518, 2013. ,
The loss of orthogonality in the gram-schmidt orthogonalization process, Numerical Methods and Computational Mechanics, vol.50, issue.7, pp.1069-1075, 2005. ,
Rounding error analysis of the classical gram-schmidt orthogonalization process, Numerische Mathematik, vol.101, issue.1, pp.87-100, 2005. ,
Matrix Computations, 1996. ,
Total and selective reuse of krylov subspaces for the resolution of sequences of nonlinear structural problems, International Journal for Numerical Methods in Engineering, vol.94, issue.1, pp.60-83, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00782841
Methods of conjugate gradients for solving linear systems, Journal of research of the National Bureau of Standards, vol.49, pp.409-436, 1952. ,
, Math kernel library
Block iterative methods and recycling for improved scalability of linear solvers, Proceedings of the International Conference for High Performance Computing, Networking, Storage and Analysis, SC '16, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01357998
Iterative methods for solving linear systems with multiple right-hand sides, CERFACS, 2003. ,
A modification to the GMRES method for ill-conditioned linear systems, 1995. ,
Deflated krylov subspace methods for nearly singular linear systems, Journal of Optimization Theory and Applications, vol.72, issue.3, pp.441-457, 1992. ,
A restarted GMRES method augmented with eigenvectors, SIAM Journal on Matrix Analysis and Applications, vol.16, issue.4, pp.1154-1171, 1995. ,
GMRES with deflated restarting, SIAM Journal on Scientific Computing, vol.24, issue.1, pp.20-37, 2002. ,
Deflation of conjugate gradients with applications to boundary value problems, SIAM J. Numer. Anal, vol.24, issue.2, pp.355-365, 1987. ,
The block conjugate gradient algorithm and related methods, Linear Algebra and its Applications, vol.29, pp.293-322, 1980. ,
Approximate solutions and eigenvalue bounds from krylov subspaces, Numerical Linear Algebra with Applications, vol.2, issue.2, pp.115-133, 1995. ,
Recycling krylov subspaces for sequences of linear systems, SIAM Journal on Scientific Computing, vol.28, issue.5, pp.1651-1674, 2006. ,
The Iterative Solution of a Sequence of Linear Systems Arising from Nonlinear Finite Element Analysis, 2005. ,
A rayleigh-ritz preconditioner for the iterative solution to large scale nonlinear problems, Numerical Algorithms, vol.17, issue.3, pp.279-311, 1998. ,
Iterative Methods for Sparse Linear Systems, Society for Industrial and Applied Mathematics, 2003. ,
A deflated version of the conjugate gradient algorithm, SIAM Journal on Scientific Computing, vol.21, issue.5, pp.1909-1926, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00523686
GMRES : A generalized minimal residual algorithm for solving nonsymmetric linear systems, SIAM Journal on Scientific and Statistical Computing, vol.7, issue.3, pp.856-869, 1986. ,
A GMRES convergence analysis for localized invariant subspace ill-conditioning, SIAM Journal on Matrix Analysis and Applications, vol.40, issue.2, pp.542-563, 2019. ,
Parallel scalable unstructured CPR-Type Linear Solver for Resevoir Simulation, SPE, vol.96809, 2005. ,
On the convergence of restarted krylov subspace methods, SIAM Journal on Matrix Analysis and Applications, vol.22, issue.2, pp.430-452, 2000. ,
, The MPI Core, vol.1, 1998.
A survey of subspace recycling iterative methods, 2020. ,
Krylov subspace recycling for sequences of shifted linear systems, Applied Numerical Mathematics, vol.81, pp.105-118, 2014. ,
Comparison of two-level preconditioners derived from deflation, domain decomposition and multigrid methods, Journal of Scientific Computing, vol.39, issue.3, pp.340-370, 2009. ,
Constrained residual acceleration of conjugate residual methods, SPE 13563, 1985. ,
