Mixture Martingales Revisited with Applications to Sequential Tests and Confidence Intervals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2021
Wouter M. Koolen
  • Fonction : Auteur
  • PersonId : 976655
This paper presents new deviation inequalities that are valid uniformly in time under adaptive sampling in a multi-armed bandit model. The deviations are measured using the Kullback-Leibler divergence in a given one-dimensional exponential family, and may take into account several arms at a time. They are obtained by constructing for each arm a mixture martingale based on a hierarchical prior, and by multiplying those martingales. Our deviation inequalities allow us to analyze stopping rules based on generalized likelihood ratios for a large class of sequential identification problems, and to construct tight confidence intervals for some functions of the means of the arms.
KK21.pdf (138.71 Ko) Télécharger le fichier
hal-01886612 , version 1 (03-10-2018)
hal-01886612 , version 2 (27-11-2018)
hal-01886612 , version 3 (07-12-2021)
Emilie Kaufmann, Wouter M. Koolen. Mixture Martingales Revisited with Applications to Sequential Tests and Confidence Intervals. Journal of Machine Learning Research, 2021. ⟨hal-01886612v3⟩
204 Consultations
592 Téléchargements
