Variance computation of modal parameter estimates from upc subspace identification, IOMAC-7th International Operational Modal Analysis Conference, 2017. ,
Uncertainty quantification for modal parameters from stochastic subspace identification on multi-setup measurements, Mechanical Systems and Signal Processing, vol.36, p.2013 ,
Fast multi-order computation of system matrices in subspace-based system identification, Control Engineering Practice, vol.20, issue.9, pp.882-894, 2012. ,
Efficient multi-order uncertainty computation for stochastic subspace identification, Mechanical Systems and Signal Processing, vol.38, pp.346-366, 2013. ,
The modal assurance criterion (MAC): Twenty years of use and abuse, Journal of Sound and Vibration, vol.37, 2003. ,
Variance estimation of modal parameters from output-only and input/output subspace-based system identification, Journal of Sound and Vibration, vol.379, pp.1-27, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01328435
Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008. ,
DOI : 10.1016/j.ymssp.2007.10.009
, Structural-Vibration-Solutions-A/S. ARTEMIS MODAL PRO 6.0, 2018.
Subspace Identification for Linear Systems, 1996. ,
