Graph drawings with relative edge length specifications, Proceedings of the 26th Canadian Conference on Computational Geometry, 2014. ,
The complexity of minimizing wire lengths in VLSI layouts, Inf. Process. Lett, vol.25, issue.4, pp.263-267, 1987. ,
Planar embeddings of graphs with specified edge lengths, J. Graph Algorithms Appl, vol.11, issue.1, pp.259-276, 2007. ,
Separability and topology control of quasi unit disk graphs, Wireless Networks, vol.17, issue.1, pp.53-67, 2011. ,
Graph Drawing: Algorithms for the Visualization of Graphs, 1999. ,
Angles of planar triangular graphs, SIAM J. Discrete Math, vol.9, issue.3, pp.349-359, 1996. ,
Convex optimization methods for sensor node position estimation, Proceedings IEEE INFOCOM 2001, The Conference on Computer Communications, Twentieth Annual Joint Conference of the IEEE Computer and Communications Societies, Twenty years into the communications odyssey, pp.1655-1663, 2001. ,
Fixed edge-length graph drawing is NP-hard, Discrete Applied Mathematics, vol.28, issue.2, pp.111-134, 1990. ,
Algorithms for drawing media, Graph Drawing, pp.173-183, 2004. ,
Combinatorial optimization in VLSI design, D: Information and Communication Security, vol.31, pp.33-96, 2011. ,
Quality ratios of measures for graph drawing styles, Proceedings of the 26th Canadian Conference on Computational Geometry, 2014. ,
Unit disk graph approximation, Proceedings of the DIALM-POMC Joint Workshop on Foundations of Mobile Computing, pp.17-23, 2004. ,
Finding the intersection of two convex polyhedra, Theoretical Computer Science, vol.7, issue.2, pp.217-236, 1978. ,
Robust positioning algorithms for distributed ad-hoc wireless sensor networks, Proceedings of the General Track: 2002 USENIX Annual Technical Conference, pp.317-327, 2002. ,
